Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 18th December 2011, 02:41 PM   #921
Russ White's Avatar
Send a message via Yahoo to Russ White
Auto-mute is a completely different feature from normal muting.
But yes, you can implement mute in firmware if you like. The current AC2 firmware I am using does that. And yes, it will work just fine with Buf32.
Less pulp more juice Twisted Pear Audio.
Old 3rd March 2012, 10:09 PM   #922
C37 is offline C37  Belgium
I am also a late adopter of the 32S, bought S/H from a member here after nerve wrecking attempts to buy a BII. Completed a month ago, still in a temporary set (in a old empty chassis from a 100W amp kit from Velleman). So far, really good with volumite directly in a set of active Tannoys in balanced.
May i report that this board seems to respond well to the sand bag tweak à la Jon Risch, i've tested this for the past 3 days much to my (grinning) satisfaction. Other owners might want to investigate...
Old 4th March 2012, 01:16 AM   #923
In my case, i am using a zip bag filled with about 800 gr of sand, covering the entire board and + 3cms on L/R lateral side (using what i had handy).
i had concerns about the heat melting the plastic zip lock in the beginning since the board get quite warm on their own, but it turns out sand is getting only slightly warmer than my hand after 24hr turn on (20° ambient) so it's ok for now.
"Amp "( Dac) case is sitting on the floor for now, resting on half inflated inner bicycle tyre.
I will keep this "tweak" when i will put my dac in its final case.
Old 4th March 2012, 09:57 PM   #924
BrianDonegan's Avatar
A bigger concern will be overheating the components on the board, since they will no longer have adequate ventilation. I would not recommend doing this.
That being said, as long as you understand the risks, feel free to tweak and experiment; I in no way wish to dissuade people from doing so.
Twisted Pear Audio
Old 5th March 2012, 08:16 PM   #925
Indeed. Heat is a concern. The Sabre chip was quite hot to the touch on its own. With the sand bag i can't tell for sure.
I did a search today and even the most conservative figures of thermal conductivity for sand and the Polyethylhene film from the ziploc seem to be at least 5...10 times better than air:
Air: 0.024 w/m.°c
Sand: 0.15 >> 0,25 w/m.°c (I've seen much higher figures around)
Polyethylhene: 0,25 w/m.°c
Maybe i am missing something? if thermal build up is a concern, i could heatsink the sand bag itself. Oh well. I do like what hear though. Though decisions...
Old 5th March 2012, 08:21 PM   #926
avr300 is offline avr300  Denmark
avr300's Avatar
Originally Posted by C37 View Post
.. i could heatsink the sand bag itself...
LoL. Finally something new 'round. That I'll like to see
Join http://TurnMeUp.org
Old 5th March 2012, 09:37 PM   #927
Russ White's Avatar
Air: 0.024 w/m.°c
One thing you might be missing is that with free air beside conduction there is convection and radiation to disperse heat.
Old 5th March 2012, 09:40 PM   #928
The way I see it is - air moves and carries heat away, while sand pretty much just sits there getting hot. Maybe you could devise some sort of sand circulatory system .
Old 5th March 2012, 09:43 PM   #929
Of course Russ would have to come along and make it sound all scientific, thereby making me look a bit of a dimwit .
Old 5th March 2012, 09:56 PM   #930
Point noted!
Page generated in 0.10847 seconds (74.24% PHP - 25.76% MySQL) with 11 queries
