Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 14th May 2010, 12:55 AM   #901
nycavsr2000 is offline nycavsr2000  United States
Twisted Pear Audio - Buffalo32S (ES9018 DAC)
Hi fellas,
Okay, I've waited one week. Is this thread being read anymore or is my post a little too germane?
Thanks,
Anand.
Old 14th May 2010, 01:00 AM   #902
Russ White is offline Russ White  United States
Russ White's Avatar
Originally Posted by nycavsr2000 View Post
Brian & Russ (and anybody else who has the answers!):
I am a little late to the game of building up my Buffalo 32S dac (2nd generation). The version of the circuit board is 1.1, purchased in June 2009.
1) The parallel lines marked in 4 spots on the output section of the board should be cut if using this in a standard stereo system (non-headphone system) right? I've been told that the dac sounds a lot better with the lower output impedance.
2) On the reverse side of the board, there appear to be four areas where there are pictographs of resistors at locations R47-R50, I take it this is where I would solder my 2K resistors to set the output voltage to 2V rms output balanced and 1V rms output unbalanced?
3) If I am just using this with standard SPDIF digital input, I don't need to mess with any of the DIP switches right?
Thanks,
Anand.
Sorry for some reason I did not see this till now.
1) If you are driving an amplifier directly I would definitely cut the traces as indicated. It help keep the very fast opamps stable driving capacitive loads.
2) Correct.
3) Correct no need to set any other DIP switch than the one that is labeled "SPDIF"
I apologize for not seeing this earlier.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 6th January 2011, 07:50 PM   #903
Thumbs up Buffalo 32S build
You can read about my build here. Includes pictures and description. Later on, I will provide a description on how it compares to 3 other dacs. Stay tuned.
Thanks to Russ and Brian of course.
Anand.
Old 25th February 2011, 04:46 PM   #904
scanspeakman is offline scanspeakman  Netherlands Antilles
After using the buffalo32s on a very audiophile piece of plywood for a year and a half, I finally found some time to build a nice casing. See below for pictures. No front yet but that will be fixed shortly.
My brother designed a nice display. rotary encoder and IR-control for the input selection. When you turn the encoder, the display will light up to 100%. After 5 seconds the light intensity will lower to about 30%.
I still love this DAC, especially with my Squeezebox Touch. Perfect combination.
Scanspeakman
Scanspeak rules!
Old 1st March 2011, 04:02 AM   #905
Russ White's Avatar
Nice work! I bet it does sound great!
Audio
Old 5th May 2011, 12:41 AM   #906
headrott is offline headrott  United States
Default I promised some people a review of the Buffalo II with Tube-I-zator boards in output.
Here is the link on the Tube-I-zator board DYIAUDIO web page for pictures and a small review of the Buffalo II and Tube-I-zator SRPP output stage boards. Phenominal sound quality and I highly recommend building one!! Please ask questions if you have them. The link is here: http://www.diyaudio.com/forums/group...ml#post2561770 and it's post #519.
Greg
Old 19th September 2011, 01:59 AM   #907
Hopefully, some people still read this thread!
Quick question.
I have my Buffalo 32S set for 2V rms through the balanced XLR outputs and 1V rms for single ended. If I want 4V rms balanced/XLR and 2V rms single ended do I remove resistors R47-R50 and replace them with just wire?
Thanks,
Anand.
Old 20th September 2011, 11:15 PM   #908
Russ White's Avatar
Anand,
Sorry I failed to notice this until now.
Just omit those resistors. Do not jumper.
Audio
Old 1st December 2011, 08:10 PM   #909
I have been using my Buffalo 32S for quite a while now. Still working great but I came up one digital (optical) input short. So I ordered an extra toslink module and a volumite. Today I have changed the (unused) AES/EBU input for a second toslink input. Works perfect after shorting R7 on the 4:1 MUX (as discribed in the manual).
Since I do not have any analog sources anymore, I wanted to try the volume control of the ESS9018. So I also added a Volumite. This is where I am having a problem. Seems to work fine but the DAC loses lock every 5-10 seconds for a very short while. Disconnected the Volumite and replaced the original firmware on the buffalo32s pcb and everything works fine again (but of course no volume control). Anybody any ideas what might be causing this strange behaviour?
Scanspeakman
Scanspeak rules!
Old 1st December 2011, 08:15 PM   #910
Russ White's Avatar
Sounds like you may need the high bandwidth firmware. The DPLL setting is a bit lower in the volumite firmware than in the original buf32S firmware.
Cheers!
Russ
Audio
Twisted Pear Audio - Buffalo32S (ES9018 DAC)Hide this!Advertise here!
