Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 7th February 2010, 03:42 PM   #851
Originally Posted by Russ White View Post
Hi Greg,
Looks like a fun project!
Either 5V or 6V is OK, 5V will keep the temps down a bit. I don't have any evidence that one "sounds" better than the other.
Cheers!
Russ
Thanks Russ. I'll drop the voltage on the Placid down a bit then.
And it has been a fun project... taken me MUCH longer to get to this stage than I planned, but it was definitely not the fault of the Buff32 or the Placids.
Really looking forward to seeing what the BuffII will do here.
Later!
Greg in Mississippi
Everything matters!
Old 7th February 2010, 03:48 PM   #852
Bunpei is offline Bunpei  Japan
That's not to say that is the only way they are used, just that it is all I have seen.
In the 2L HiRes Download - test bench, they say
High Resolution Music DOWNLOAD services
"Prior to entering a commercially available download service for high resolution audio files we invite you to join us in this evaluation of future consumer delivery formats. FLAC is a lossless encoding of WAV-files derived directly from our production original used for the SACD. All resolutions and encodings are derived from the same original DXD source files. ... "
I understand that they record their master in DXD format files and edit, mix down and down-sampling into release masters for SACD, CD, mp3, etc.
When I asked the importance of playing 192 kHz/ 32 bit files, an expert replied to me;
"No need for 192 kHz/ 32 bit replay because no recording on 32 bit. DXD is more important."
Bunpei
Old 7th February 2010, 04:07 PM   #853
Russ White's Avatar
Send a message via Yahoo to Russ White
Hi Bumpei,
I was only relating my (very limited) personal experience with DXD. I am quite confident if they say they are recording to directly DXD that they are.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 7th February 2010, 04:23 PM   #854
It is my understanding (I work around studios) that most DXD files are simply converted from DSD. Am I wrong about this? I have not really studied it so I could well be.
In any case, have every reason to believe it would play them in the same way the demo did.
I would be happy to test it.
Cheers!
Russ
Thanks Russ
Go for it!!
You will be compesated by many.
Cheers
Old 7th February 2010, 05:21 PM   #855
Dear Russ,
thanks for taking the time to see if you can arrange a test. You will really be in the high tech frontline with DXD testing
Well my experience is not much with DXD honestly.
I will see what I can arrange in the way of a test.
Cheers!
Russ
Old 7th February 2010, 05:22 PM   #856
steve jones's Avatar
A question for Russ. What is the current requirement for VD? I'm going to use another supply than a Placid.
Old 7th February 2010, 05:35 PM   #857
Russ White's Avatar
It draws ~ 250ma in the standard configuration.
I would use 5.5V
Cheers!
Russ
Old 7th February 2010, 08:38 PM   #858
Magsy is offline Magsy  United Kingdom
Is 5v pushing it? are the on board regs going to drop out ~5v? (how much headroom?)
Is there a schematic for IVY III I can have a peak at?
Old 7th February 2010, 08:42 PM   #859
Russ White's Avatar
Are we talking about Buf II?
Nothing will drop out at 5V, in fact things should be OK down to 4.5V. Its just that the AVCC reg will do slightly better at the top of its input range which is 5.5V.
I will publish the IVY III schematics soon, but not yet.
Cheers!
Russ
Old 7th February 2010, 09:05 PM   #860
Thanks, understood! I was going to use a 5v reg and wanted to be sure of the reason to use a little more (5.5v)
Copyright ©1999-2013 diyAudio
