Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 6th February 2010, 02:37 PM   #811
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
Thanks Russ,
It looks really excellent.
When the AVCC module is included, why have it on a separate PCB?
Old 6th February 2010, 02:44 PM   #812
Russ White is offline Russ White  United States
Russ White's Avatar
Originally Posted by Joshua_G View Post
Thanks Russ,
Two reasons.
1) Routing optimization. I laid it out that way because it allows me to better bypass and route the DAC board keeping critical nets as short as possible. It also lets me better layout the AVCC module itself concentrating on it as a unit. The net lengths actually end up shorter than if I had tried to squeeze it on the DAC board. I did not want to compromise here.
2) It's flexible. You can drop just about any 3.3V supply there you like. This is appealing to some DIY folks.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 6th February 2010, 04:28 PM   #813
glt is offline glt  United States
Originally Posted by Russ White View Post
1) Yes its included.
Keep in mind the maximum input voltage for the AVCC module is 5.5V and the minimum is 5V.
Cheers!
Russ
Must put a large warning sticker. In the past, all modules with on-board regulators were taking 5-8V
www.hifiduino.wordpress.com
Old 6th February 2010, 04:31 PM   #814
Default Question on IVY III
Each channel has two differential opamps, how is it configured? Thanks.
Old 6th February 2010, 04:32 PM   #815
Russ White's Avatar
It will be prominent in the manual.
We will also put it on the web page.
Audio
Old 6th February 2010, 04:33 PM   #816
Russ White's Avatar
Basically it is an I/V stage followed by a filter/buffer.
Audio
Old 6th February 2010, 04:55 PM   #817
MrMajestic is offline MrMajestic  Sweden
MrMajestic's Avatar
Is the middle power entry (PWR3) on the IVY only powering the Ballsie section?
Old 6th February 2010, 04:59 PM   #818
Russ White's Avatar
If you do not install J1-4 yes. If you install the jumpers you only use one supply for all three sections, which is in no way to be though of as sub-optimal. Once again I was just trying to be as flexible as possible to support DIY folks who may want to try all sorts of things.
Cheers!
Russ
Audio
Old 6th February 2010, 05:19 PM   #819
SoapSeller is offline SoapSeller  Israel
Both 5.08 and 2.54mm connectors can be used, am I correct? Nice if you stack the boards so you can skip running wires.
Can someone point me to the connectors that will allow me to skip the wires?
Old 6th February 2010, 05:22 PM   #820
Russ White's Avatar
Just use sufficiently tall male pin headers on one side, and female on the other.
Cheers!
Russ
Audio
Twisted Pear Audio - Buffalo32S (ES9018 DAC)Hide this!Advertise here!
