Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 5th February 2010, 09:46 PM   #791
Beefy is offline Beefy  Australia
Originally Posted by Russ White View Post
Actually should not be too hard to fit if you use one Placid BP and one Placid.
You just know some people will want that 3db extra DNR from the dual mono config.
Oh come now, Russ. We all know that Each half of each IVY needs its own separate Placid......
Old 5th February 2010, 10:00 PM   #792
Russ White is offline Russ White  United States
Russ White's Avatar
Ok, well I personally might be temped to use one placid/placid BP per mono channel, but I would not go beyond that.
Still you never know with some folks.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 5th February 2010, 10:15 PM   #793
Magsy is offline Magsy  United Kingdom
If there are decent onboard regs and the shunt is there already for avcc, do we really need a shunt external or can we just feed it a reasonable regulated 5v? (LM317 etc)
If going two board dual mono, how do you feed them/sync them together? (I2S input)
Thanks!
Old 5th February 2010, 10:21 PM   #794
Russ White's Avatar
Yes the on-board regs are quite good.
A good LM317(or LM317/LM337 for bipolar) based supply like the LCBPS/LCDPS is perfectly fine.
Still it does not hurt anything to use something a bit better for the pre-regulators. And thats the attraction of the Placid/Plaicd BP.
I would say the biggest impact would be felt in using the Plaicd-BP for the IVY-III, but you would still get superb results with the LCBPS because the PSRR of the IVY-III is excellent.
Cheers!
Russ
Audio
Old 5th February 2010, 11:01 PM   #795
Thanks Russ, F5 key at the ready
Old 6th February 2010, 12:12 AM   #796
Will2 is offline Will2  Bermuda
Forgive the ignorance but is this BuffaloII a drop-in substitute for the Buffalo32s?
Old 6th February 2010, 01:58 AM   #797
Russ White's Avatar
Buffalo II + IVY III would be yes (just a bit taller). And it has the added bonus of a balanced to single ended converter for both balanced and single ended output at the same level.
You would have had to add a Ballsie Lite(or similar circuit) to get the same thing with Buffalo32S.
Audio
Old 6th February 2010, 02:02 AM   #798
SoapSeller is offline SoapSeller  Israel
Originally Posted by BrianDonegan View Post
I will probably add some combo options for the buffalo as well, but not sure what at the moment. I will probably just do Buffalo, IVY III, Placid, Placid BP combo, though you could add a second Placid BP for dual-mono.
Cool, can't wait to order(/build/listen) (:
Also, if you want to do what I am calling mondo-dual-mono (two BII's in mono mode, each separate feeding an IVYIII) I will throw in the alternate IVYIII resistors*
Tempting, very tempting...
Old 6th February 2010, 06:46 AM   #799
Spirit02 is offline Spirit02  Peru
I'm assuming as it uses the same chip that the volumite for the B32S will work in a B-II?
Old 6th February 2010, 09:53 AM   #800
acidbrain is offline acidbrain  Netherlands
acidbrain's Avatar
Twisted Pear Audio - Buffalo32S (ES9018 DAC)
Seems like this moment is the eye of the tornado before the first counter onTP's site goes to zero. Xellent time for (noob)questions.
- I want to use three BP placids for the Ivy III
- Three single voltage placids for the BII
Does one of those SP placids feed the "included AVCC shunt" ?
Or must I use another 2 SP placids
I have a Philips CDpro-2lf player/chassis and want to use the I2S output.
6 pins : EF/SCLK/WCLK/DATA/GND/V4.
- How do I connect it to the BII with best sample rate setting ?
I also have a Metronome
-Can I still use the Volumite, which also uses the the I2S header on the BII ?
Thanks !
Twisted Pear Audio - Buffalo32S (ES9018 DAC)Hide this!Advertise here!
