Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 9th August 2009, 06:04 PM   #611
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
Hi Russ,
Thanks.
The Denon player itself don't have a DSD mode. Is there a possibility to externally switch the player's DAC to DSD mode?
The OTTO switch will be needed to switch between DSD and the MUX/Receiver output.
Old 9th August 2009, 07:45 PM   #612
Russ White is offline Russ White  United States
Russ White's Avatar
When the player is playing an SACD it is in DSD mode.
You could use a simple manual toggle switch to switch between PCM and DSD input on the DAC. No reconfiguration of the DAC itself is required.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 9th August 2009, 08:36 PM   #613
Joshua_G's Avatar
Thanks.
1. The Buffalo DAC will decode either SACD DSD stream from the player, or the output of the MUX/receiver, which is I2C PCM (or so I believe). So, it seems to me that what I'll need is OTTO switch and no other switching at the DAC, while I may need to reboot the DAC after switching input stream. Is that right?
2. Is there any benefit in using shielded cable for the SACD DSD stream?
Old 29th August 2009, 03:20 AM   #614
toufu is offline toufu  United States
Hi guys, will the whole thing fit into a 12x12x4 box?
Old 29th August 2009, 10:25 PM   #615
Javin5 is offline Javin5  Switzerland
If you mean inches, then yes, it will fit. You will even have quite a bit of empty space.
Kurt
Old 30th August 2009, 03:05 AM   #616
Russ White's Avatar
Indeed it will fit quite easily.
Audio
Old 31st August 2009, 11:53 AM   #617
lindamar is offline lindamar  Spain
Location: Madrid - Capital of the Kingdom of Spain / European Union
I received my buffalo32s a few days ago, impressive packaging, impressive finishing !!. It is singing beautifully in my system already.
I have a very simple question though: how do I "short" L1 and L2 on the back of the PCB??? (I must be holly lost in translation, but cannot figure out what is the right thing to do here...and I read the whole forum!!)
Any help would be much appreciate it. A picture is attached just to illustrate how dumb a newbie can be... The only way I could figure out to "short" L1 and L2 is the one you see in the picture, by joining together the two outer grounds of the board... is that correct at all ?
Any help would be much appreciated. Thank you
Pepe
Old 31st August 2009, 12:04 PM   #618
Russ White's Avatar
Pepe
Hi Pepe,
On the latest boards L1 and L2 are already shorted with a jumper (0R Resistor). No need to jumper.
That wire there won't really hurt anything, but it won't help either.
There should be a new version of the manual up very soon. Sorry for the confusion.
Cheers!
Russ
Audio
Old 31st August 2009, 12:12 PM   #619
Thank you Russ !!! , holly molly...fast answer!!
I read in the forum as well that there will be available new boards without the IVY analog section, do you have an idea about availability ?
Thank you !.
Cheers, Pepe.
Old 31st August 2009, 12:15 PM   #620
NicMac is offline NicMac  Italy
NicMac's Avatar
Twisted Pear Audio - Buffalo32S (ES9018 DAC)
I might be wrong but it looks to me that you have the new board and that the jumpers are already in there. They are the short connections between the two external (analog) and the central (digital) ground planes. What you have done is to join the two analog ground planes, which will hardly do any good (or bad) as these are already both joined to the digital ground.
Nic
Sorry for this but it is hard to beat Russ speed in helping out!!!!!!!
Twisted Pear Audio - Buffalo32S (ES9018 DAC)Hide this!Advertise here!
