Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 8th August 2009, 03:22 AM   #601
glt is offline glt  United States
HDMI was invented for two purposes: one to simplify cabling and two to ensure high resolution signals are securely delivered to the rendering device (i.e., the digital signal not captured through other means). This means that whoever is implementing HDMI in the sending and receiving end must sign a license and among other things the license legally enforces you to ensure that the digital signal is never exposed until rendered to analog.
But if you can tap into the DSD signals in the clear, you can feed them to Buffalo... Some have done that with some Denon players
www.hifiduino.wordpress.com
Old 8th August 2009, 03:58 AM   #602
Thanks.
I thought HDMI is protected only for video.
Any idea which Denon Players?
Old 8th August 2009, 06:37 AM   #603
NicMac is offline NicMac  Italy
NicMac's Avatar
Buffalo takes DSD so if you can locate the non-coded signal in the SACD player you are in luck. It's quite easy on some players but you will have to do some research on your own model.
Nic
Old 8th August 2009, 10:41 AM   #604
Does anyone have info about Denon DVD-3930 DSD?
Old 9th August 2009, 03:16 AM   #605
BrianDonegan's Avatar
Find out what DAC chip it uses (most likely the TI DSD179x). Look up the datasheet, and find the DSD signal pins. Trace them on the board to a convenient place to tap them and you are in business.
Old 9th August 2009, 02:37 PM   #606
Hi Brian,
Thank you very much.
Old 9th August 2009, 02:49 PM   #607
The DAC is Burr-Brown PCM1796. I have its' Data Sheet. What pin letters refer to the DSD?
Old 9th August 2009, 03:14 PM   #608
pins 1-3
Old 9th August 2009, 03:52 PM   #609
Thanks.
1. Pins 1-3 are labeled ZEROL, ZEROR, MSEL. To what input pins in Buffalo32s DAC each one should be connected?
2. Do I need connect DGND from the player to the DAC?
3. Would a shielded cable for the DSD have any benefit?
Old 9th August 2009, 04:30 PM   #610
Russ White's Avatar
Send a message via Yahoo to Russ White
On the PCM1796 when it is in DSD mode:
Connect DGND from the player PCB to GND at the Buf32S input.
Pin 7 is the bit clock: connect to DCK on the Buf32S.
Pin 5 is Left channel data: connect to D1 on the Buf32S.
Pin 4 is Right channel data : connect to D2 on the Buf32S.
This will only work correctly while the player is in DSD mode.
If you want to switch between DSD and PCM you will need something like an OTTO.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Copyright ©1999-2013 diyAudio
