#521 | |
Andy |
#522 | |
In fact I plan on having that in the next batch of boards I order.Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#523 | |
I don't mean this badly, but this has been said a hundred times. The Buffalo32S board is not designed to be used in that way. I don't have time to support such modifications. This is why it is a finished module, not a kit or bare PCB. There will be a board without output stage I suggest anyone who wants to design an output stage use that board when it is available. Cheers! Russ
#524 | |
#526 | |
Twisted Pear Audio |
#527 | |
Absolutely, my apologies Brian. I was just excited about how it sounded. Both you guys are the best and I can't believe how much work you put into making these kits. Craig |
#528 | |
Is the board big enough for boutique cap like Nichicon Muse? Cheers, Sam |
#529 | |
Yes I believe they would fit. I gave something like 12-13mm around the big caps. 5mm pitch.
#530 | |
Andy |
| Thread Tools | Search this Thread |
