#501 |
I would defintely agree with that, now crappy recordings which didnt bother be before as much are almost painful to listen to... I was listening to a classical CD of mixed composers and I could hear them flipping pages in the background, and a guy sweeping or humming or something...
but the good recordings are almost blissful... I have some Dave Matthews live that was well recorded and you can here the plucking of the guitar and its amazing... |
#502 |
Hope i can afford to buy one someday
You describe the sound with same words i use when i heard tripath for the first time. Anybody use Buffalo32S with tripath amp?
Music is the only art in real time.... |
#503 |
Yes, using Amp4 (Tripath amp from 41hz) after a B32S. It's important to feed a Tripath/dig. amp with batteries! I feed it with 24V batterie. Excellent sound! It's the best amp i had till now. Cheap also.
#504 | |
Kurt |
#505 | |
Scanspeakman
Scanspeak rules! |
#506 |
Hey folks,
New placid adjustable shunt regulating power supply boards have been ordered for testing. I should have them in a couple of weeks. ![]() I will let you know how it goes. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#507 |
They look bigger than the LCBPS. What are the dimensions? And will you offer a LCDPS equivalent as well?
[EDIT] Two sets of trimpots? Beyond my skill to work out what is going on there ![]() Oh, and off topic...... I was on Facebook this morning, and both Brian Donegan and Russ White came up as friends suggestions. How in the hell could Facebook make that connection?!? |
#508 |
Yes they are a bit bigger than LCBPS. I needed to have space for the big heatsinks and I also wanted to lay it out in a way that makes it possible to mount directly to a metal case allowing the case itself to be the heatsink.
3" x 3.5" Facebook works in mysterious ways... ![]() Cheers! Russ
#509 |
The two pots will be pretty easy to understand with the manual.
![]() One sets the current through the CCS (this will effect maximum output current). One sets the output voltage. The practical range for this PS is ~ +/-3.3V to 20V or so. I am not sure on the top end yet. Cheers! Russ
#510 | |
| Thread Tools | Search this Thread |
| Page generated in 0.11723 seconds (77.07% PHP - 22.93% MySQL) with 11 queries |
