Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 8th June 2009, 04:52 PM   #491
hybride is offline hybride  Netherlands
Brian, Russ, What is the best way to connect I2S wires from the juli@ soundcard to the B32S (to prevent ringing) Better use serie resistors (20-30ohm) or straight connection? plz advise..
Old 9th June 2009, 12:32 AM   #492
Nielsio is offline Nielsio  Netherlands
Nielsio's Avatar
I'll be running the following setup:
[PC] Emu 0404 AES/EBU -> Behringer DEQ2496 AES/EBU -> Buffalo32 -> JLTI Tube buffered chip-amp.
Do I need to cut the output traces?
Behringer DEQ2496 . Twisted Pear Buffalo II DAC . JLTi tube buffered LM3875 . Supravox 215 Signature Bicone 125L vented
Old 9th June 2009, 12:50 AM   #493
Russ White is offline Russ White  United States
Russ White's Avatar
Yes, I would.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 9th June 2009, 12:51 AM   #494
Russ White's Avatar
The digital lines already have a series resistance, but it is ok to add a bit more if you like.
I would just wire it directly and try that first.
Audio
Old 9th June 2009, 02:39 AM   #495
Nielsio's Avatar
Ok,
Two questions:
1. I ordered one of these:
http://www1.conrad.nl/scripts/wgate/...mh_area_kz=8A#
I don't think it comes with a fuse. What fuse should I use?
2. Am I supposed to do something with the potentiometers on the power supplies?
Old 9th June 2009, 02:47 AM   #496
Russ White's Avatar
Ok,
Two questions:
1) I don't think it comes with a fuse. What fuse should I use?
2) Am I supposed to do something with the potentiometers on the power supplies?
1) 1A fuse should be fine.
2) Yes, you adjust the voltages to those recommended in the manual with them.
Please be careful. You may want some help.
Audio
Old 9th June 2009, 04:45 AM   #497
thomaspf is offline thomaspf  United States
Originally posted by Russ White
Yes, I would.
Hi Russ,
I have been thinking about the measurments on my Buffalo32 and I of supposedly would execute those at full volume with my JT2. Isn't the JT2 just a bit of cable extension at that point?
Would it not be better to also enable the resistors for this case? Will it have ayn detrimental effect on the signal if you enable the resistors on the board and then run the signal through a specific set of volume resistors on the JT2.
Cheers
Thomas
Old 9th June 2009, 07:23 AM   #498
scanspeakman is offline scanspeakman  Netherlands Antilles
1A is fine but 500mA works as well. I expect even 250mA to be fine. The DAC does not draw that much.
Nielsio: if you need advice how to adjust the power supplies send me an email lekkerlichaam<apestaart>hotmail<punt>com
Scanspeakman
Scanspeak rules!
Old 9th June 2009, 11:05 AM   #499
Javin5 is offline Javin5  Switzerland
http://www1.conrad.nl/scripts/wgate...mmh_area_kz=8A#
I ordered two of those a few weeks ago. They came with a fuse. However, they had bare connections and wiring with the mains voltage exposed on the back, so be careful!
Kurt
Old 10th June 2009, 07:48 AM   #500
Yesterday evening I listened to the Buffalo32s more closely. I found two "disadvantages".
1) CD's with crappy recordings already sounded like crap on my Marantz CD6002 but now they sound even worse....
2) The bass seems to be extended to even lower frequencies; now my couch is sometimes vibrating
More serious: this DAC is brutally detailled. It has been a while since the haires at the back of my neck raised with some live recordings. I can only confirm what other people said before; very good imaging and depth. With great recordings my audio system now really sings! And it is still improving.
Scanspeakman
Scanspeak rules!
Twisted Pear Audio - Buffalo32S (ES9018 DAC)Hide this!Advertise here!
