#411 | |
. Hugs .
#412 | |
Its all about what you want to listen to. For me B32s is the recipe, but maybe its not for the rest of the world. That leaves you to find out what you want. Imo, there is no shortcut. |
#413 |
I am very happy with my new Buffalo32S. Brian and Russ have produced an amazing DAC.
The Buffalo32S is stunning. I did not expect such a leap in soundstage and detail compared to the Perpetual DAC. Music is more enjoyable even at lower volume levels, there is so much more detail and pinpoint location of instruments and vocals. I use surplus dual linear power supplies which have LM723 regulators. They were already set up for +/- 15V @ 1.5A operation. I had to modify one of them to get +5V which was a little challenging since the supplied schematic did not match the actual units. These supplies are probably overkill. I am using the I2S outputs from Juli@ sound card, each connected to rather long RG174 mini coax cables due to the layout of my office. I have been driving the Perpetual P-3A ( soon to be up for sale, I think ) in this configuration for a year or so. Lock ON is instantaneous. I am using the latest version of cPlay with the SOX upsampler at 96kHz. cPlay has two upsamplers each with different upsampling rates, so I will be trying different configurations. No fancy packaging for me yet. I just attached the power supplies to a piece of poplar, the DAC to a chunk of that "clipboard" pressed board material. |
#414 | |
To Brian and Russ - it has been a pleasure to build the psu's and put the Buffalo together - worked first time - no problems locking, no nasty high-pitch noises - nothing but music. A very satisfied customer.
#415 |
I can only confirm this. The 32s is indeed amazing. I had mine up and running one hour after the package arrived (using previously assemled LPBPS and LPDPS). In the absence of music, there is absolute silence when turning up to full volume, not a trace of hum or hiss. And it immediately locked in narrow to the SPDIF-outputs of three differnt players I tried. I'm not an expert in soldering, but I had no problem so far with any of the TP-kits, all parts clearly labeled, easy to assemble. And I experienced a truly first rate customer service from Russ and Brian when I had a question. I really don't know how they find the time for this, with all the other work, but somehow they do. Thanks a lot!
#416 |
can we have more people comparing the buffalo 32 to their previous DAC? like DAC-AH, MF X-DAC, TDA1541A NOS, WM8410, other CDP (accuphase, Rotel, Cambridge ) etc...
How's the mid, high, low, decay, soundstage, etc before and after buffalo 32? I just happen to hear a buffalo sabre, 9008(IVY + LPBPS and LPDPS). Wasn't impress due to the extreme dull/ dark sounding presentation (IMO which I simply cannot accept). This is why I am really hesitant to get one, B32s. Thanks in advance. Hi Russ/ Brian, I am not trying to ruin ur thread but just gathering honest opinion.
#417 |
Are you really going to rely on what someone else's ears (read as lots of personal interpretation) tell them about lows, mids, highs, soundstage to make a purchasing decision? Thats like asking someone to test drive a car for you and then you go buy it! I think all you can rely upon is that many people like it and thats about as far as you can take a comment like that without hearing it...
I just find it interesting on what people need or what qualifies as decision makers nowadays... |
#418 | |
Kurt |
#419 | ||
I just wanted to be sure coz I read too many good user reviews to hear something very contradicting. I am also guessing... undue mods may have being done to it. |
#420 |
I have heard in my system (some of these belong to me)
Theres others I tried but the below is the ones I've had Benchmark DAC1 Modded Beresford TC7510 Buffalo+IVY totally rigged out with Paul Hynes shunt regulation ,Russ's latest filter for the IVY Buffalo32S currently using Paul Hynes regulation for the VD and VA Pedja Rojic AYAII (upgraded with TDA1541S2) One of those CS4397 Ebay dacs (highly modified) PCM1794 Ez dac , various TDA1543 including Audiosector based and a Storm audio Pandora using x 16 parallel chips Various diy 1 x and 2 x TDA1541A's with various output stages TDA1545 Monica3 For me three dacs stood out between these, The modded Buffalo, Buffalo32s and the AYAII If I'm honest the modified Buffalo gave the new and fresh (not much burn in ) Buffalo32s a hard time, one thing the modded Buffalo dac wasn't and that was dull/dark sounding, its dynamics was some of the best I've heard, bear in mind its regulation was not standard and this to me had a large impact on the sound, also the newer IVY filter made a difference Buffalo32s is now maturing nicely and continues to improve, tbh I was a little disapointed at first but now its had a week or so on it , the grounding issue now sorted and since adding the shunt regulation its sounding much more to my taste, it now does some things better than the modded Buffalo AYAII will always remain one of my favourite sounding dacs, this is a personal thing, some music with this dac just sends me into a trance, it does not have the dynamics of the modded Sabres though |
| Thread Tools | Search this Thread |
