#11 |
Great work! Can we expect enough Buffalo32s board's in first batch for all awaiting customers? In other word's; will it become a time-competition to get one from the first batch? Hope you will accept a list of pre-orders in the coming weeks ;-) I want 3 boards ;-))) |
#12 |
It's impossible to predict demand, especially with a wobbly economy.
We are getting doing a large initial batch, and planning a second large batch a few weeks behind that. Hopefully the first batch lasts a while and the second batch will stay in stock for a while, but who knows. Once we have a couple of the first boards built and running, we will open up orders while I build the rest. If needed, we will take orders for the second batch before we even order boards, and can make that batch as large as needed.
Twisted Pear Audio |
#13 |
Thanks,
Smart approach. |
#14 | |
Just curious why not 3.3x4? which is 2X the old form factor. I suppose it is not designed to be stacked with other/older modules. For example, PSes in the bottom Sabre32S on top... Also, is it compatible with Volumite? |
#15 |
and hopefully also a perfect companion for the balanced Joshua Tree that I just ordered.....
#16 | |
Absolutely. Will work just fine.
Less pulp more juice Twisted Pear Audio. |
#17 | |
Definitely not designed to stack. It is compatible with Volumite. Cheers! Russ
#18 |
What is the word on DSD for the Buffalo 32S? I am really hoping that did not get cut.
#19 | |
It is still supported. It will operate very much like the current Buffalo. In fact it should actually be simpler to mod SACD players with this module than with the original Buffalo + IVY as the total package will be a bit smaller(unless you stacked I guess). Cheers! Russ
#20 |
SE: 2Vrms
BAL: 4Vrms
| Thread Tools | Search this Thread |
| Page generated in 0.13108 seconds (76.32% PHP - 23.68% MySQL) with 11 queries |
