Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 10th April 2009, 03:44 AM   #141
Russ White is offline Russ White  United States
Russ White's Avatar
Originally posted by Beefy
Looks great Russ
Any opinions on how much of the new improvements are the Sabre32 chip, versus the IVY II and new board design?
Hi Beefy,
Thanks for the nice comments from you and the rest of you folks. So many of you I have learned from. My respect to you. You know who you are.
Well, to your question, I would say a lot of both.
Let me be less obtuse. I think the ES9008 would be better on the new PCB with the new circuit changes. But I think the ES9018 is even better still.
I am very very pleased with the changes on the new chip. Dustin and his cohorts did a great job. It is much easier to work with and I think the digital filter is better. The DPLL bandwidth is even lower now (1/64th the ES9008 if I remember correctly) which means that jitter is even less.
All in all in I think it's a great synergy. I hope you agree.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 10th April 2009, 07:23 AM   #142
thomaspf is offline thomaspf  United States
Hi Russ,
thanks for posting the numbers and the graph, that looks very impressive.
One additional question. Are the numbers unweighted?
Cheers
Thomas
Old 10th April 2009, 11:02 AM   #143
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
Default Re: Ap Fft
Originally posted by Russ White
Here is the FFT at 1khz 0db.
Very impressive.
Old 10th April 2009, 03:01 PM   #144
mavallarino is offline mavallarino  United States
mavallarino's Avatar
Wow, impressive, but what does it all mean?
I will wait for the DAC only version. But can I really wait that long?
I have to congratulate the twisted pear people for the great persistence and drive to create such nice products and their dedication to diy community.
Waiting for the DAC only version...
Old 12th April 2009, 12:27 PM   #145
alboran is offline alboran  Italy
good morning
me to want to understand well..
if me to buy new buffalo32s.. me to be able to use other Ivy expresses?
transformer.. buffer to tubes.. etc
or new buffalo32s to only work with integrated IVYII?
graces and regards
Old 12th April 2009, 04:02 PM   #146
Joshua_G's Avatar
It was said few times here.
1 version will be with integrated I/V.
Second version will be without integrated I/V, so you may use any I/V you wish.
Old 13th April 2009, 01:01 PM   #147
TheShaman is offline TheShaman  Europe
Concerning the "tweaker's" version coming out next, it should be noted though that the added bonus of flexibility will lead to a few compromises, as Russ has pointed out:
Making a board "tweakable" means two things have to be accounted for. First, it will definitely not be suitable for beginners, and we will not cater to beginners with it. Second, it really cannot be routed as well as a finished solution because quite simply, you have to make design decisions final to optimally route a board. Building in flexibility means compromise. You will have much more to wire, and you will have much longer signal routes. That is the compromise. There is no way around it.
...don't expect the same kind of Dynamic range as can be done on a single board, as it is simply not possible.
Old 13th April 2009, 02:51 PM   #148
fff0 is offline fff0  Singapore
Hi Russ,
Is the packaged B32S shown on the website to make a complete ready to play standalone DAC, other than adding a suitable transformer?
# Buffalo DAC + Power Supply Combination [1] Buffalo DAC Module (Assembled and Tested)
# [1] Low-Current Dual Power Supply Kit
# [1] Low-Current Bi-Polar Power Supply Kit
Any general recommendation for a transformer spec?
As per your website's tx, 2 of them ?
Old 14th April 2009, 07:10 AM   #149
rjbaldwin is offline rjbaldwin  United Kingdom
Originally posted by fff0
Hi Russ,
Well, you will need the supporting hardware and stuff to connect it up and stuff to put it in. You will need two transformers if using the two power supplies. I guess you could probably get away with a 9v for the digital side / LCDPS, (Russ/Brian correct me if I'm wrong here for the Bufallo32s,) but much depends on what else you are connecting to this power supply. You would need the 15v for the LCBPS for the analogue side I think.
Old 16th April 2009, 09:41 PM   #150
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Twisted Pear Audio - Buffalo32S (ES9018 DAC)
I have updated the Buffalo page with the times for the pre-orders of the 32s. There was also a small adjustment to the pricing.
Basically, at 8PM (20:00) Friday April 17th (Eastern Standard Time) I will enable pre-orders of half of the available DACs. The second half will go on sale 12 hours later, on Saturday morning at 8AM (0800).
If you to the the page and see the buttons enabled, there are still DACs available.
To simplify things, I have added the count-down timer again.
Twisted Pear Audio - Buffalo32S (ES9018 DAC)Hide this!Advertise here!
