Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 9th April 2009, 01:02 PM   #131
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally posted by scanspeakman
If you want to be sure, and use a output cap with the buffalo32s, what should be the value? I see people use values between 0.47microF and 4.7microF.
Scanspeakman
Unless you are playing DC samples there is no need for one, but if you want one the value will depend on the load. Google "RC filter". But usually 1-2uf suffices.
Less pulp more juice Twisted Pear Audio.
Old 9th April 2009, 11:18 PM   #132
Russ White's Avatar
Cool Buffalo32S Test Results
So, here it is folks.
I have for you the first measurements for Buffalo32S.
Naked board no case or any shielding.
I am very, very, pleased.
I could have achieved a bit better DNR if I used some more aggressive filtering, but the trade off would have been higher output impedance. All in all I am extremely happy. Especially since you can drive headphones etc directly from this DAC.
For instance the ESS demo board measures slightly better, but has a very high output impedance. That's the trade off. Now if you drive cables with a high impedance and have to add an additional stage to drive your headphones you will probably end up with for worse spec then if you went directly out of the Buffalo32S.
Anyway I am very very pleased. 127db DNR is perfectly fine by me.
I enjoy listening to it much better than measuring it.
Code:
DNR          THD+N 1kHz  THD+N 20kHz
Single Ended Output
-123                -117             -117
Single Stage Differential Output
-129                -116             -117
Normal Differential Output(low impedance)
-127                -118             -117
Cheers!
Russ
Old 9th April 2009, 11:45 PM   #133
Send a message via Yahoo to mikelm
mmm - very impressive that ur 20kHz Figures are the same as 1KHz
Can I ask what power supplies you used during this test and what is the current status of placid ?
can't wait to hear it
mike
Old 9th April 2009, 11:45 PM   #134
Hi Russ,
Excellent compromise. Bless your hands and mind.
Old 9th April 2009, 11:51 PM   #135
Russ White's Avatar
mike
Thanks.
Huge kudos to Brian for getting the prototypes done so quickly. It would not have happened without him there.
The supplies were bone stock LCDPS and LCBPS.
Placid works well and I use it form time to time, but it still needs some redesign to be ready for the public.
I will keep you guys posted on our site about Placid.
Cheers!
Russ
Old 10th April 2009, 12:09 AM   #136
HaLo6 is offline HaLo6  United States
HaLo6's Avatar
So this means "out of stock" should change soon!!!
Old 10th April 2009, 12:12 AM   #137
BrianDonegan's Avatar
I will be opening pre-orders early next week. Details to follow soon.
Twisted Pear Audio
Old 10th April 2009, 02:08 AM   #138
Russ White's Avatar
Default Ap Fft
Here is the FFT at 1khz 0db.
Old 10th April 2009, 02:15 AM   #139
cuibono is offline cuibono  United States
cuibono's Avatar
Thats pretty smooth!
Old 10th April 2009, 02:42 AM   #140
Beefy is offline Beefy  Australia
Looks great Russ
Any opinions on how much of the new improvements are the Sabre32 chip, versus the IVY II and new board design?
Copyright ©1999-2013 diyAudio
