#981 |
pic nr 2
#982 | |
#983 |
pic nr 3
#984 | |
I spend a lot off time to listen between my Sphinx project nine and Philips SACD1000 with APL modification, not alone but with friends and my wife , we all agreed that the sound was much more detailed and 3d without fatigue, you can listen the whole day long without feeling the need to lower volume or get irritated. Anyway I am very happy. |
#985 |
Hi Russ and Brian ,
I ve sent you an email to orderstatus at twistedpear. Have you received it? Vitaly |
#986 | |
A satisfying improvement, I thought, although I had been very impressed with the unmodded IVY. I'm not much up on the audiophile lingo, but I'd definitely say that a veil or two has been dropped, and the highs had gone from (comparatively) steely and bright to a wonderful caramel color (flavor?). Of course, the Buff in now ruthlessly revealing of any deficiencies in the source material. Thanks again guys, for a great product and great service. - Pat
www.buyoutdickvitale.com: Pledge money to enable ESPN to get Dickie V off the air |
#987 |
OK, this is my (limited) understanding of the analog power path.
the regulator buffer looks like a voltage follower preceded by a CRC filter. So the CRC filters the high frequency noise and the voltage follower just passes the remaining noise to the DAC supply pins? The input to this buffer is output of the analog LDO regulator. Most regulators have noise figures in the 10s-100s uV. So, if the local LDO noise figure is inherent in the device, how can cleaning the upstream noise (e.g. TPA dual PS) reduce this noise? In other words, if you chain several regulators, you can improve load and line regulation, but is the output noise dominated by the noise of the last regulator? Thus it seems to me that the noise of the local LDO filtered by the CRC is the inherent noise of the buffalo analog supply line. (Plus the noise of the opamp but this is probably in the nV range) |
#988 |
What is the gain of the IVY Balanced Linestage?
#989 | |
Also, If you look at the spectrum of the noise which needs to be filtered it is all (or rather nearly all) high freq. (80 and 160mhz mostly) Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#990 | |
0db from the DAC results in an output of ~2 VRMS.
| Thread Tools | Search this Thread |
| My ESS Sabre Buffalo DAC | Algar_emi | Digital Line Level | 10 | 5th March 2009 01:19 PM |
| Page generated in 0.12832 seconds (84.69% PHP - 15.31% MySQL) with 11 queries |
