#601 |
#602 | |
It would work just fine, but a dual secondary transformer might get you a bit better result. If you just want to use what you have, go for it. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#603 | |
Very nice work! Cheers! Russ
#604 | |
Actually I'm using this for a Hypex UCD amp. I'm replacing the on board feed for the input opamp supply which is unregulated with this supply which is regulated. The transformer for the amp has an extra secondary for low voltage but it is center tapped. With this wiring I'm still using the CLR for the + and - legs. Would the choke filtering not work as such? I'm waiting for placid/counterpoint to use in the buffalo which I'll build in the same case, then I will use the dual secondaries transformer. Thanks for all the replies... |
#605 |
The DAC is sounding exceptionally good but I have a problem:
I am getting crackling which is associated with the signal. i.e. no signal: silent, with signal: crackling - spread evenly in left & right channels but always in dead centre. SPDIF, all settings default, V output via transformers. Bal toUnbal I will try USB soon to see if that is better but before that do you have any ideas what is causing this ? I attach pictures mike |
#606 |
the crackling is constant when there is a signal - like a fire or frying pan. Not very loud - but clearly audible.
#607 | |
Do you have an alternative SPDIF source to try? Re-terminate and re-route your SPDIF wiring? |
#608 |
thanks beefy - I'm just trying SPDIF via USB module which seems to be TTL 3.3V cos it has just locked on D1 i/p of DAC . . . .
. . . . mmmmm seems to be better, clicking is gone but it seems to sound different now but still sound pretty good |
#609 | |
Ah yes, that makes sense. When using TTL level SPDIF you should not use the comparator input, but instead open the SPDIF switch and wire the SPDIF into D1. Don't forget to open the SPDIF switch. Cheers! Russ
#610 |
I begin to see that each configuration is going to have it's own "sound"
1) Pioneer universal player SPDIF out into DAC SPDIF in - I really like this sound apart from the clicking - it sounded very analogue - I wonder what I have to do to get this mode working properly ? I need this mode to play movies ! 2) USB module in SPDIF mode into D1 i/p sounded more detailed but a bit rough - didn't like that. I wonder if the USB module would sound better with it's own supply ? 3) USB module in SPDIF mode into DAC SPDIF i/p - sounds best so far on balance - not as nice as 1 but better than 2 and no clicking - oh Russ just say - should not use this mode - will it damage anything Russ ? next I try USB via I2S . . . |
| Thread Tools | Search this Thread |
| My ESS Sabre Buffalo DAC | Algar_emi | Digital Line Level | 10 | 5th March 2009 01:19 PM |
| Page generated in 0.11894 seconds (82.61% PHP - 17.39% MySQL) with 11 queries |
