Buffalo DAC (ESS Sabre 9008) - Page 50 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 4th October 2008, 09:21 AM   #491
avr300 is offline avr300  Denmark
avr300's Avatar
Originally posted by Russ White
Nikola, switch 3 should always be low "-".
It actually controls the quantizer setting.
There is an issue when trying to run the 9-bit quantizer (which is default) so please set it low to run the 6-bit quantizer setting.
Cheers!
Russ
Is this still applying to firmware 1.0.3. Will switch 3 control the 6/9 bit quantizer in firmware 1.0.3 ?
Old 4th October 2008, 11:41 AM   #492
BrianDonegan's Avatar
No. Version 3 has reverted the switch back to controlling the notch filter.
Old 4th October 2008, 05:19 PM   #493
grimberg's Avatar
Brian,
The package arrived yesterday and this morning I opened it and checked all the boxes and bags. Unfortunately the TOSLINK module did not arrive. Also, the Buffalo board does not have the socket and PIC processor in the IC4 position, nor were they included in the box. That presents another problem since I was counting on the Buffalo to be tested by you guys, as I have no experience troubleshooting a DAC.
Old 4th October 2008, 07:57 PM   #494
Originally posted by coloradosound
I have a Denon DVD-2910. I see in the other thread that some
including Russ have modded their Denon players to run this
board in stereo. When the Buffalo becomes available again,
would I be able to use three Buffalo's and get full surround?
Would it be possibe to do for both SACD and DVD-A's?
If so, would anybody have some direction on doing that?
I'm also looking for SM/schematic for DVD-2910.
Anyone, Anyone, Beuler, Beuler?
Old 4th October 2008, 09:12 PM   #495
avr300's Avatar
Then it's using 6 bit quantizer ?
And regarding the notch filter, pls. explain the use of the switch ? To be more specific, which register of the Sabre is controlled by switch 3. I can't find anything in the datasheet that I can relate to notch filter, or notch delay, as described in the manual.
It's properly just me....
Tia.
Old 5th October 2008, 12:05 AM   #496
Russ White's Avatar
Send a message via Yahoo to Russ White
LOL, It certainly is possible to do what you want But not something exactly trivial to explain. I just returned from an extremely fun but grueling week at Disney World. I will get back to this tomorrow.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 5th October 2008, 12:08 AM   #497
Russ White's Avatar
Tia.
Correct. 6bit it is, which as it turns out seems to be the most ideal setting in any case.
The notch filter is not documented in the datasheet, but Dustin informed me that when set to div/64 with the 6-bit quantizer it gives you just a bit better DNR (1 or 2 db).
Cheers!
Russ
Old 5th October 2008, 06:17 AM   #498
chobint is offline chobint  United States
Forgiving the unorthodox pre-layout, are there any forseeable problems mounting the torroids this closely to eachother?
The alternative would be to mount them on opposite sides of the plate. Thanks.
Old 5th October 2008, 12:01 PM   #499
Russ White's Avatar
Either mounting choice should work just fine.
Pretty cool!
Old 5th October 2008, 11:14 PM   #500
Brian,
Sorry about that. The last few that went out were a separate batch and I forgot IC4 for each of them. I'll send you IC4 tomorrow morning.
As for testing, I do that on a jig I made up, and use the uC header rather then the firmware on IC4. That's just the problem though. I did the testing, and just packed them up, forgetting the final step in my haste.
My ESS Sabre Buffalo DAC Algar_emi Digital Line Level 10 5th March 2009 01:19 PM
Copyright 1999-2017 diyAudio
