#2071 |
#2072 | |
Switch to spdif. I experienced the exact type of dropouts on I2S (but not on the spdif line) but for a different device (Musiland MINI). For me, I had to increase the bandwidth of the dpll (but you need to program the chip to do that).
www.hifiduino.wordpress.com |
#2073 | |
#2074 |
Hmmm. Good to know. That makes two devices for which Apparently the SPDIF is better than the I2S going into the Buffalo and your device is the well known PCM 2707. I wonder if there is something else at play...
www.hifiduino.wordpress.com Last edited by glt; 17th December 2010 at 04:46 AM. |
#2075 |
Guys, count me in on the hiccups issue with Buff II and I2S. I'm using Teradak USB-SPDIF-I2S converter with Tenor 7022 chip. The hiccups are exactly the same.
Glt, thanks for the tip about switching to the SPDIF. Or maybe it is possible for you to upload firmware with increased DPLL? If it is allowed by NDA. ![]() Thanks, Fedor |
#2076 | |
#2077 |
I am using an Arduino to control the DAC. I had programmed the controller to vary the bandwidth. So I just dialed one at a time until the hiccups disappeared.
However, 3 devices where the I2S is "worse" than the spdif cannot be a coincidence. There has to be something else...
#2078 |
Hi glt, thanks for the answer.
Seems, that only other option is to wait for Russ to finish his XMOS USB transport device.
#2079 |
This SPDIF is fundamentally easier to lock just because of the way the chip decodes it.
Unfortunately the PC2707 has quite a lot of phase noise on the bit clock, especially for 44.1khz playback. It is because of the PCM2707 pretty crude analog PLL. The clock is actually derived, and not really well. That is why for Opus we generally recommend people use it SPDIF out(so that it would be reclocked be a receiver) or with Metronome for best results. For Buffalo I would definitely suggest SPDIF out.
Less pulp more juice Twisted Pear Audio. Last edited by Russ White; 17th December 2010 at 12:22 PM. |
#2080 |
On thing I am thinking of doing for next firmware revision is making the DPLL BW adaptive. So that it will auto adjust to your source.
Less pulp more juice Twisted Pear Audio. |
| Thread Tools | Search this Thread |
| My ESS Sabre Buffalo DAC | Algar_emi | Digital Line Level | 10 | 5th March 2009 01:19 PM |
