Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 17th February 2010, 04:07 PM   #2031
BrianDonegan's Avatar
Do you know if it has better phase noise spec than the 25-50 ppm standard part?
I believe the phase noise is the same for all versions of the CCHD XOs.
Would heatsinking (like those in the VGA chips) be beneficial?
I don't think it would hurt, but probably no benefit either.
Twisted Pear Audio
Old 17th February 2010, 04:27 PM   #2032
Originally Posted by glt View Post
I think the real reason for Buf II was to 1- to satisfy people like us with the urge to tweak everything (thus we hang around in this diy board :-)) and 2- to price it more competitively to reflect present market conditions.
The original reason for Buffalo II was to have a tweakers board.
Old 17th February 2010, 05:01 PM   #2033
Originally Posted by BrianDonegan View Post
The actual XO is the same as the one on the Buff32.
Interesting reading here ....
http://hifiduino.blogspot.com/
Old 26th April 2010, 01:59 AM   #2034
theob is offline theob  United States
Default Question for Brian or others knowledgeable on Buf32s
I tried a bit of gooey damping compound on top of the Sabre Dac chip (none of it touches the lead outs) and it made a significant improvement in SQ. Is this practice safe, are there any risks like excessive heat?
Old 26th April 2010, 02:19 AM   #2035
Russ White's Avatar
Send a message via Yahoo to Russ White
It shouldn't be a problem so long as your prevent shorts.
I can't say I endorse the practice however.
Less pulp more juice Twisted Pear Audio.
Old 26th April 2010, 02:38 AM   #2036
Beefy is offline Beefy  Australia
No, really, you should try it. Chewing gum in particular is great for freshening the sound.
Old 26th April 2010, 04:42 AM   #2037
Does it make it mintier?
Old 26th April 2010, 11:55 AM   #2038
Sure. Why not.
Old 8th May 2010, 06:59 PM   #2039
ghg is offline ghg  Austria
ghg's Avatar
Default Are all Buffalo 1 ( ESS 9008 ) boards factory tested ?
Hi
Well, I took a closer look at my Buffalo Rev. 1.2 board and it seems,
as there are some pins of the ESS 9008 connected, bad soldering.
I state, maybe, cause even using a magnifying glass, I am not sure.
So, before assembling, my question ,are these factory tested ?
BR
Gary
I hate "sounding amps", except these are Marshalls, driven by Eric C. or Jeff B., period.
Old 8th May 2010, 07:01 PM   #2040
If you can call my basement a factory, than yes.
There are some pins that are supposed to be joined on the dac.
Twisted Pear Audio
My ESS Sabre Buffalo DAC Algar_emi Digital Line Level 10 5th March 2009 02:19 PM
Page generated in 0.09693 seconds (92.16% PHP - 7.84% MySQL) with 11 queries
