Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 20th January 2009, 10:15 AM   #1311
masi is offline masi  Switzerland
Thanks for the compliments.
It's a Hifi-2000 Case (Galaxy GX288) supplied from audiophonics.fr in France.
The metal work (back panel and insertion panel) comes from schaeffer-ag.de. I wasn't aware that Hifi-2000 is offering that kind of service. With these panels you really get a professional look, there's no way I could have done that myself. One blemish may be the blank outside edges but AFAIK you could have drilled and cut your own materials.
I like the Galaxy case. It looks really neat and the aluminum side profiles allowed the insertion of a mounting panel. Like that, mounting is straight forward, everything perfectly on its place.
Analog and digital signal wires are well separated from power supply and control wires which are routed underneath this panel. Thereís no hum or hiss or anything like that to hear on the speakers.
So far Iím running my DAC without the top cover to please myself with the interiors - maybe I should get a transparent acryl cover.
masi
Old 21st January 2009, 03:50 PM   #1312
oj is offline oj  United States
Default last Ivy mods
I am about to complete a Buffalo/Ivy combination. I was wondering what is the final and, possibly, best configuration of IVY that is holding after all your experimentations.
In particular,
C1-4: 4.7nF or 10nF?
R17-20: jumper or 21R?
R1-4: 187R or 357R or jumper?
R5-8: jumper or 187R?
C13-16:2.2nF or 10nF?
Thanks guys.
Old 21st January 2009, 03:58 PM   #1313
Russ White is offline Russ White  United States
Russ White's Avatar
Default Re: last Ivy mods
In particular,
1) C1-4: 4.7nF or 10nF?
2) R17-20: jumper or 21R?
3) R1-4: 187R or 357R?
4) R5-8: jumper or 187R?
5) C13-16:2.2nF or 10nF?
Thanks guys.
This is what I suggest.
For 2VRMS output:
1) 10nf
2) jumper
3) 187R
4) jumper
5) 10nf
For 4VRMS output:
1) 4.7nf
2) jumper
3) 357R
4) jumper
5) 10nf
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 21st January 2009, 04:06 PM   #1314
thanks Russ!
Just an additional question on the Buffalo. What are the following two dip switch controls: (i) notch delay and (ii) DPLL BW?
Old 21st January 2009, 04:16 PM   #1315
Russ White's Avatar
thanks Russ!
Notch delay adds a 1/64 delay to the modulator which is supposed to improve DNR slightly.
DPLL bandwidth is either LOWEST or MEDIUM. Best jitter ejection is achieved at LOWEST, but some poor quality sources will not lock (or stay locked) well with this setting. For those sources its better to use the MEDIUM setting.
Cheers!
Russ
Audio
Old 21st January 2009, 04:27 PM   #1316
boudy is offline boudy  United States
Default Re: Re: last Ivy mods
For 2VRMS output:
1) 10nf
2) jumper
3) 187R
4) jumper
5) 10nf
For 4VRMS output:
1) 4.7nf
2) jumper
3) 357R
4) jumper
5) 10nf
Cheers!
Russ
Cheers!
Russ
It would be EXTREMELY helpful if all of these excellent nuggets of information were added to the relevant manuals and the TP website.
It is an extreme PITA to sift through these mega-threads looking for useful information.
I also find it odd that customers are not directed to the support forum on the TP site. Isn't that its intended purpose?
Otherwise, keep up the excellent work.
Old 21st January 2009, 06:15 PM   #1317
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
I agree
Old 21st January 2009, 09:44 PM   #1318
UKPD is offline UKPD  United Kingdom
Default Simple Reg.
Hi, there.
First introduction, my name is Peter, I've been following this forum for awhile now and finally decided to post.
Question is: has anybody tried that Simple reg from Russ (post1097) and what are the component values?
Thanks,Peter.
Old 22nd January 2009, 01:25 PM   #1319
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Buffalo DAC (ESS Sabre 9008)
This message is for Russ.
Hi. I'm referring to the Buffalo Vref schematic, version 2.0 and PCB posted on page 44. Since the parts values are not indicated, I recovered most of them from the schematic page 45. But both schematics are not exactly the same. Can you check my parts list so I can be sure of the schematic values?
C1,2,3,4: 100uF, low ESR
CBP ?
CComp ? (optional) but what range
R1: 4K7
R2: 1K
R3: 12K
R4: 680 or 221R
R5: 221R
R6?
RE ?
RF: 1K
VRG: ? Pot range?
D4: 1N914
IC1: LT1115
Q1,2: BC556 or BC560
QN1A (TO92): BC556 or
QN1B (TO220): ?
Thanks...
Old 22nd January 2009, 03:53 PM   #1320
Russ White's Avatar
Here you go.
Hopefully this PDF will shed some light on that VREG design.
I know a couple of you guys have asked for it, now you should have plenty to go on.
Forgive any typos/mistakes as I wrote it quickly and did not have much time to proofread.
I have tried the circuit, it does work.
The pass device needs to be chosen for the load and drop, and also used with adequate heatsink if required.
The input voltage cannot be greater than the maximum supply voltage of the opamp, and cannot be less than 5V or so. You may need to adjust some parts/values based on your input voltage.
:EDIT: fixed the gain formula in the PDF.
:EDIT2: Fixed a couple typos and added the VREF label.
Cheers!
Russ
Audio
Buffalo DAC (ESS Sabre 9008)Hide this!Advertise here!
My ESS Sabre Buffalo DAC Algar_emi Digital Line Level 10 5th March 2009 02:19 PM
