#1101 | |
This regulator is designed to be used after a LCDPS. The VREF alone is not meant to drive the LM4562 at all. It is there to provide the low noise 3.3V reference that the opamp tracks. The opamp *is* the VREG. The VREF's output impedance on its own is not stellar. It has to used with a very high input impedance, like the opamp. With the exceptional PSRR of the LM4562 the LCDPS should work out very well. But you can use any regulator you like as long as you get a good low impedance 6 - 8V or so. Try the VREF on the buffalo and see what you think. I am really liking it. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#1102 | |
I am glad you are enjoying it. Cheers! Russ
#1103 | |
Russ, If this becomes a product (please, please) you can add a pad to the Vref so the same board so it can be used for a Vref or Vreg. Thanks! |
#1104 |
Hello
I hope there is anybody around who can help. Yesterday I was happy, because the AV Ref mod works very well. Then I wanted to add the MUX, but it does not work at all. I have checked everything: layout in the net and on the board of the buffalo are different, I don't know which is correct, I have tried both, without success. When I follow the I2S markings on the board, buffalo locks, but the LED on the MUX is dark, even If I connected the missing ground link (I have an early board). I have connected input one, for this select 1 and 2 are tied to gnd. switch 1 on buffalo is neg I have left the switches on the mux untouched. All the voltages are O.K. I soldered the relays that their point is on the same corner as the small white dot on the board. When I switch to SPDIF, buffalo works, but with added clicks sometimes. Thank you! André |
#1105 |
Hi Andre
If you put the I2S output of the MUX board against the I2S input of the buffalo board, the terminals will line up. Here is a pic I hope will help. I have GND connected elsewhere, thats why you don't see it. Data,BCK,LRCK Add GND if your MUX and Buffalo don't share a common supply.
#1106 |
Also, you cannot leave the switches open. Try setting them like this.
#1107 |
Hello Russ
Buffalo and Mux are stacked, but DOUT to D2 LRCK to D1 BKC to DCK is correct I think. I just hear loud hiss with faint music. Ground is everywhere. Relays are O.K? thank you! André |
#1108 |
If you have a very very early Buffalo (very first run) remember that D2 and DCK are swapped.
Also, isolate the MUX itself and make sure its locking. Is the LED installed backward?
#1109 |
My buffalo is from the second round, the one with the hosting company problems you had.
I have removed the mux now, unsoldered and checked the LED, flat side is connected separately to ground. selectors 1 and 2 still to ground, no lock! Slowly I start to think about to replace it with another mux. Thank you for your help Andre |
#1110 |
Yes, it sound like the MUX might be suspect.
If it won't lock on its own, then there is no point to proceed with it. I guess maybe it could be a solder bridge or a dry joint. Very sorry your having trouble with it.
| Thread Tools | Search this Thread |
| My ESS Sabre Buffalo DAC | Algar_emi | Digital Line Level | 10 | 5th March 2009 01:19 PM |
| Page generated in 0.14807 seconds (78.11% PHP - 21.89% MySQL) with 11 queries |
