Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 11th December 2007, 05:34 AM   #21
JonPike is offline JonPike  United States
Hmmmm.... after waiting forever and getting teased with promises that never pan out... (for TI's 1794 demo board) this sounds very interesting!
Can you give us some idea when these might be an available product?
Old 11th December 2007, 11:24 AM   #22
BrianDonegan's Avatar
I have about 20 boards that I need to build up. Should be next week. I'll get something up on the site for them.
Twisted Pear Audio
Old 21st January 2008, 12:19 AM   #23
Russ White's Avatar
Send a message via Yahoo to Russ White
Default COD with TXD as I/V stage
I have been listening to the COD now for a few weeks. Mostly with the passive I/V (270R resistor) into the ballsie. This sounds very good. But not really as good as the Opus.
Well I put back in the active I/V stage by putting the cap jumpers in (shorting them) and removing the resistors to GND, so that the DAC is now DC coupled to two TXDs with only THS4141s in them. This is MUCH better. Not just a little. The best way to describe the difference is just simply to say there is an apparent change in resolution. Dynamics just seem more realistic and alive.
Anyway here is how it looks in my test rig with the TXDs as I/V converters right before the ballsie.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 21st January 2008, 06:22 PM   #24
I have made the remaining beta COD modules and boards available on our site (on the Opus page for now). They are the same as the production boards except for some layout tweaks and we replaced the jumpers with dip switches.
Twisted Pear Audio
Old 22nd January 2008, 05:26 AM   #25
neb001 is offline neb001  United States
Default Re: COD with TXD as I/V stage
When you say it's much better, did you mean in comparison to the opus or in comparison to the previous setup with the passive i/v?
Old 22nd January 2008, 11:25 AM   #26
Russ White's Avatar
Default Re: Re: COD with TXD as I/V stage
I meant better than the passive I/V + Ballsie. Though that setup is still very good!
Cheers!
Russ
Old 22nd January 2008, 11:39 AM   #27
kstagger's Avatar
can't offer much on the technical side, but I'm running a PCM1794 via the K&K RAKK DAC using a Lundahl transformer for the IV conversion / outputs. Sounds very good - would like to see your results since the line transformers raised the price of the RAKK considerably.
Old 22nd January 2008, 11:49 AM   #28
Russ White's Avatar
Some one one told me this:
Voltage sources like to see a high impedance, and current source like a low impedance.
Well the TXD configured for I/V is about as low as you can get impedance wise. It just in the 10s of milliohms.
At first I was not confident this would make much difference, but it really does. Everything just seems cleaner, not colored.
With passive I/V the sound is still good, but very definitely with a "warm" coloration.
Cheers!
Russ
Old 24th January 2008, 10:18 PM   #29
Russ White's Avatar
Default Now this I like! :)
I decided to show the COD with TXD I/V and a Joshua Tree attenuator after each I/V, the output of the attenuator goes to the ballsie where the output is filtered and buffered. From there SE outputs go to my head amp and balanced out to the power amp.
Oh yes, there is a metronome in there too.
Cheers!
Russ
Old 25th January 2008, 12:58 PM   #30
So with the improvement in the powersupply you think its still not as good as the Opus?
Output Current from PCM56P K? georgehifi Digital Line Level 30 16th May 2009 07:50 PM
Reduce DAC output current ? Bernhard Digital Source 1 10th January 2006 10:46 PM
Transformer Current output ocool_15 Parts 4 3rd December 2004 07:19 AM
Figuring out Output current. mjarve Solid State 4 19th September 2004 10:29 PM
Page generated in 0.11332 seconds (79.26% PHP - 20.74% MySQL) with 11 queries
