Go Back   Home > Forums > > >
Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Donations FAQ Calendar Mark Forums Read
Twisted Pear Superior quality electronic kits
Thread Tools
Old 20th July 2012, 04:51 PM
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by Zero Cool View Post
with a 90 ohm IV resistor there is about 1v of DC offset out of the DAC. you need the caps to block this DC from a following Buffer stage or use some form of compensation like a servo etc. The distortion is very low using a resistor. I would bet an active stage would have comparable results but a different harmonic structure to the distortion.
I know the active vs passive thing has been debated to death here. but I can tell you first hand a passive IV stage with a jfet buffer sounds WONDERFUL! that is of course MPO on the subject. and YMMV but it is an easy thing to experiment with and see what works for you!
Zc
Thanks. I saw somewhere that someone varied the I/V resistor of some other kind of current output DAC and got much worse distortion readings with higher resistor values. Let me go search on the forum for something about this. I initially did a Google search and got a few results, but nothing good, hence my question here since I have this DAC and COD board.
I have a schematic for a passive I/V stage with jfet buffer. No coupling capacitor is required since the DC offset is so small that the CRD in the circuit compensates just fine. The I/V resistors are 127 ohms in this circuit, for about 1.3Vrms output.
I was playing around with a Zen type of active I/V stage using bipolar transistors but the input is very sensitive to DC offset. I put a blocking capacitor at the input (no resistors at all) and it seemed to work just fine with no loss of bass response.
I have read that the current output DAC's will output the same AC current regardless of the load impedance up to the maximum voltage they can put out, but I have not seen a specific distortion vs. impedance curve anywhere.
Old 21st July 2012, 02:54 PM
dirkwright's Avatar
I did some searching on finding a distortion vs. I/V resistor value chart or something like that with no luck. I don't think it's a linear relationship, but that's just a hunch. I do know that if the resistor is too large then the "compliance" limit will be exceeded such that the voltage output will be clipped. People keep repeating this mantra that a current output DAC must see the lowest possible load impedance but no one puts up any proof. I did a lot of searching Google and reading various websites with no luck so far. The DAC datasheets are no help, since all they say is "do it our way to achieve our results".
So, how low is low enough? 9 ohms? the Zen (Sen, Cen, etc.) only manages 15 ohms. If you use bjt's instead of jfets you can get less than 1 ohm input impedance, according to my simulations.
Also, there is a zero field transformer input circuit that can achieve very low input impedance, depending on the transformer. The Lundahl LL1517 has a winding resistance of some 9 ohms. With the zero field circuit, the input impedance can be made to be 9 ohms and the frequency response can be extended to 1 Hz. The advantage with a transformer is ground isolation. My simulations show this circuit to have high noise though, but I think that's a software issue.
Old 21st July 2012, 03:21 PM
dirkwright's Avatar
Further reading has shown that for the antique TDA1541 DAC, a passive I/V resistor of about 60 ohms is the limit. I don't know about the PCM1794 though.
Old 22nd July 2012, 02:41 AM
dirkwright's Avatar
There's some spec floating around that the DAC pins shouldn't see more than 25mV but that's probably only with the really antique DAC's.
One way to do this is to do a passive I/V with a really low value resistor, and then use a normal gain stage after that. I put the RLC filter in with the I/V resistor before the gain stage. S/N is around 120-125dB depending on what kind of gain stage is used.
Old 1st November 2012, 07:30 AM
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Testing the pcm1794
It seems like 50R resistor is the way to go for passive I/V for this DAC. I'm going to try this with the Ventus as buffer.
Old 17th December 2012, 08:42 PM
DIYspaceW is offline DIYspaceW  Slovenia
Interesting... I was experimentig with higher and lower values for I/V. I have a AD1865 and found the lower values being better for my taste. I am just curious has someone tried less then 1ohm resistor for current to voltage conversation. I know you need a phono or mic input stage but it would be interesting to try....
Old 17th December 2012, 10:32 PM
dirkwright's Avatar
I think you need about 50dB of gain. So, you can work from there.
Old 18th December 2012, 08:41 AM
Yes. thats a lot. I would need to make two gain stages for it.
Old 22nd December 2012, 05:15 PM
staki is offline staki  Switzerland
If I want to use two COD boards in dual mono configuration, what is the best solution to feed them with i2s input signals (from a USB to i2s converter) ? Just wire both PCM terminal blocks in parallel ?
Will there be a shift between the left and right data bits ?
Old 22nd December 2012, 05:17 PM
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
You just wire them in parallel, you set one board for left and one for right. I found it best to connect each board to the source with separate runs.
Zc
It's not about what you can BUY...It's about what you can BUILD!
COD - Current Output DACHide this!Advertise here!
Thread Tools
Output Current from PCM56P K? georgehifi Digital Line Level 30 16th May 2009 08:50 PM
Reduce DAC output current ? Bernhard Digital Source 1 10th January 2006 11:46 PM
Transformer Current output ocool_15 Parts 4 3rd December 2004 08:19 AM
Figuring out Output current. mjarve Solid State 4 19th September 2004 11:29 PM
Resources saved on this page: MySQL 68.42% / PHP 36.66%
Copyright ©1999-2017 diyAudio
