#111 |
Ok...
Thanks! |
#112 |
Audio Junkie
Hi, I just found out about Twisted Pair and boy have i got some questions!
I am interested in Buying the COD kit. or maybe 2. so the first question is, what is the difference in using one kit stereo, vs. 2x kits each configured for mono?? second. how do you choose the I/V stage resistor? I see that the kit uses 470 ohms while another high end DAC that uses the same PCM1794A chips uses 140 ohms resistors for the IV stage that feed a Jfet input stage. The same company that makes the DAC also uses 140 ohms in the cd player they also make for their tube buffer stage. What factors go into choosing the resistor value? I looked at the chips data sheet and couldn't find any info. I pretty much want to duplicate the whole DAC stage as used in this CD player (using the COD DAC Kit) and add the (out of stock) S/PDIF 4:1 MUX/Receiver and USB Receiver/DAC all into one unit. Zc
It's not about what you can BUY...It's about what you can BUILD! Last edited by Zero Cool; 23rd June 2011 at 02:31 AM. |
#113 | |
2) The most practical consideration is output swing. If you apply gain at the output stage then a lower output swing from the DAC is desirable. 3) That value is perfectly fine. I would strongly suggest however not using an I/V resistor at all and simply using a purpose built I/V stage like IVY-III or Legato 3.1. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#114 | |
Audio Junkie
2) Is there a perceivable sonic difference between a high ohm I/V resistor and a Lower Ohm I/V resistor if you kept the final gain the same after the output buffer? One could surmise that it might sound a bit more open and relaxed with less current through the I/V resistor? 2a) How critical is the I/V resistor in terms of sonics? is this the place to spend a few extra bucks and drop a caddock or other "high end" type tweakie resistor in there? 3) I have a specific reason to want to use a I/V resistor stage to start off with. but playing with a legato might be in the works once i get the front end running.
It's not about what you can BUY...It's about what you can BUILD! |
#115 | |
#116 |
Are the bare COD pcbs going to be available again soon?
| Thread Tools | Search this Thread |
| Output Current from PCM56P K? | georgehifi | Digital Line Level | 30 | 16th May 2009 07:50 PM |
| Reduce DAC output current ? | Bernhard | Digital Source | 1 | 10th January 2006 10:46 PM |
| Transformer Current output | ocool_15 | Parts | 4 | 3rd December 2004 07:19 AM |
| Figuring out Output current. | mjarve | Solid State | 4 | 19th September 2004 10:29 PM |
| Page generated in 0.10023 seconds (76.82% PHP - 23.18% MySQL) with 11 queries |
