Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 2nd April 2009, 05:17 PM   #91
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
COD - Current Output DAC
http://www.diyaudio.com/forums/showt...456&highlight=
Old 4th April 2009, 11:06 AM   #92
JeroenR is offline JeroenR  Netherlands
Originally posted by JeroenR
Can someone please take a look at my wiring schema? I'm not too certain I got it right....
Are the modules connected ok and is the grounding ok?
Thanks!!!
Jeroen
Anyone? Please?
Before I do the wrong thing with my iron today...
Thanks,
Jeroen
Old 4th April 2009, 01:04 PM   #93
I would join the two LCDPS GNDs at the supplies, then run a single ground to COD (they are both joined on the COD board). Also eliminate the I2S GND from Metronome.
Old 4th April 2009, 01:29 PM   #94
Hi Brian,
Thank you for taking a look at it.
Why is joining the grounds at the PS better than joining at the boards? Is it preventing from current flowing between the boards? I sort of concluded that was not possible as the boards do not share a common. Is there current flowing through the I2S lines?
Thanks,
Jeroen
Old 4th April 2009, 01:32 PM   #95
Just ground loop prevention. You would likely have no problems the way you had it. If you use the terminal blocks, you can pretty easily try it both ways.
Old 4th April 2009, 08:55 PM   #96
I soldered the boards, tomorrow I'll test with just some passive IV before I install the RAKK IV. Below is the adjusted schema, I did not add the clock to the common so it is isolated from the rest.
Jeroen
Old 4th April 2009, 09:50 PM   #97
I think you will want to link the grounds so the voltages will be relative.
Old 4th April 2009, 10:07 PM   #98
The ground from the Tent clock-out is connected to the Metronome clock ground pad...
Old 4th April 2009, 10:10 PM   #99
Russ White is offline Russ White  United States
Russ White's Avatar
That is fine, they will be linked there.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 5th April 2009, 12:12 PM   #100
Jeroen
It works.
One weird thing though... The COD and Metronome are stacked. I thought it would be wise to add some shielding in between so I added a 1.5mm alu plate (see photo). This proved a bad idea: every time I touched the chassis the sound disappeared...
Anyone knows what happened? The alu shielding/plate and chassis were in contact through the screws but there was no ground/common from the circuit connected to the chassis???
COD - Current Output DACHide this!Advertise here!
Output Current from PCM56P K? georgehifi Digital Line Level 30 16th May 2009 08:50 PM
Reduce DAC output current ? Bernhard Digital Source 1 10th January 2006 11:46 PM
Transformer Current output ocool_15 Parts 4 3rd December 2004 08:19 AM
Figuring out Output current. mjarve Solid State 4 19th September 2004 11:29 PM
Copyright ©1999-2017 diyAudio
