Go Back   Home > Forums > > >
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 30th December 2013, 11:59 AM   #41
AmadeusMozart is offline AmadeusMozart  New Zealand
Amadeus how did you do the triode mod? I really want to bypass the volume pot as well but I'm a total diy noob. Will a blob of decent solder across the pot prongs do the trick? And which prongs should I solder (looking at them from the prong side)?
Also do you live in Auckland? I live near Piha. I'll pay you in beer to do the mods for me lol.
No, I live in the Western Bay of Plenty. Got severe arthritis and do not undertake work for others, sorry. The connection between the grid (g2) to B+ has to be broken and then a small resistor (100 - 1K) been soldered between the g2 on the tube socket and the plate on the tube socket.
If you want to be a purist then the CCS can be replaced with a simple 270 Ohm resistor (leaving the capacitor in place) but it is not necessary since the CCS appears to be set to just the correct current. The CCS has an effect on the clipping though.
What is the reasoning behind wanting to bypass the potentiometer - you can just turn it full volume and then ignore it?
Old 31st December 2013, 10:43 PM   #42
uberdine is offline uberdine  New Zealand
I had one of these a while ago and after bypassing the pot the difference was startling. Imaging, presence and texture were twice as good as just having it turned all the way up. Unfortunately the amp died so I'm going to try it all over again. Fingers crossed this one doesn't cark it.
Old 4th January 2014, 01:38 PM   #43
Musik007 is offline Musik007  Hong Kong
Musik007's Avatar
APPJ EL84 SE mini Tube Amp, PA0901A
The headphone adapters are out of stock.
Old 19th January 2014, 10:08 AM   #44
Musik007's Avatar
New Year Special Offer:
APPJ PA0901A amp + Gold Lion (Genalex) Re-issue ECC83(Made in Russia) + Shuguang EL84 =USD190 + shipping cost
Black and Silver colors are available.
*** The special offer is valid until 31st, Jan., 2014.
Old 31st January 2014, 07:37 PM   #45
mimoser is offline mimoser  Austria
is there any option to cage the tubes against little fingers and nosey cats?
thx
Michael
Old 10th February 2014, 12:19 AM   #46
gaston senac is offline gaston senac  New Zealand
My APPJ EL84 SE mini Tube Amp, PA0901A has arrived
Wonderful tube amp for the money! Very happy with it.
I'll wait to get more ours before making a final review, but so far I like it a lot more than Pass Camp Amp.
I love coming back to tubes... they do many things so right that I have long missed that sound.
Thanks Tony for this wonderful little amp
Old 10th February 2014, 12:22 AM   #47
One question regarding the headphone adapter box:
It seems to be an option to buy something more than just the adapter, I mean looking at the box and the two compartments inside.
Do they come with cables or some other unit as an option?
Thank you.
Old 10th February 2014, 10:32 AM   #48
Studio Au is offline Studio Au  United Kingdom
Just to clarify, assembled? Is it possible to buy this without the case?
Hello,
No, the amps are assembled by APPJ. You can buy the assembled or finished amp.
Thanks,
Tony.
Old 10th February 2014, 02:22 PM   #49
I think what Tony meant was that it's a finished product, you can't assemble it yourself.
It comes assembled from APPJ factory.
Am I right Tony?
Old 12th February 2014, 02:58 PM   #50
Musik007's Avatar
Hello Gaston,
Yes, you are right. APPJ provides finished products only.
Thanks,
Tony.
Am I right Tony?
APPJ EL84 SE mini Tube Amp, PA0901AHide this!Advertise here!
APPJ PA0901A() schematics fx19979 Tubes / Valves 1 24th August 2013 05:27 AM
APPJ PA0901A / Miniwatt N3 schematics fx19979 Tubes / Valves 0 23rd February 2013 09:14 AM
Replacing a driver tube in an existing EL84 SE Amp corbato Tubes / Valves 29 16th February 2003 06:33 PM
