Fostex full range drive units - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 4th August 2012, 02:43 PM   #1
Musik007's Avatar
Default Fostex full range drive units
We are now supplying Fostex full range drive units at special prices.
Fostex FE series full range drive unit:
*ES cone and center cap are adapted. This new diaphragm material has the fine, supple and high density fiber and its characteristics successfully improve the mid-high frequency reproduction.
*Strong ferrite magnets are employed.
*Well tuned Qts/Mms values for ease of use in the back loaded horn enclosures.
FE83En 3" drive unit, main spec.:
*60mm diameter strong ferrite magnet
*SPL: 88dB
*Impedance: 8 ohm
*Qts: 0.84
*Frequency Response: 165Hz~30kHz
@Price: USD29.8/pc
FE103En 4" drive unit, main spec.:
*80mm diameter strong ferrite magnet
*SPL: 89dB
*Impedance: 8 ohm
*Qts: 0.33
*Frequency Response: 83Hz~22kHz
@Price: USD39.9/pc
FE126En 4.5" drive unit, main spec.:
*100mm diameter strong ferrite magnet
*SPL: 93dB
*Impedance: 8 ohm
*Qts: 0.30
*Frequency Response: 83Hz~25kHz
@Price: USD49.8/pc
FE166En 6.5" drive unit, main spec.:
*110mm diameter strong ferrite magnet
*SPL: 94dB
*Impedance: 8 ohm
*Qts: 0.25
*Frequency Response: 53Hz~22kHz
@Price: USD69.5/pc
FE206En 8" drive unit, main spec.:
*146mm diameter strong ferrite magnet
*SPL: 96dB
*Impedance: 8 ohm
*Qts: 0.19
*Frequency Response: 45Hz~20kHz
@Price: USD90/pc
The above prices don't include shipping cost and import tax.
Details:
http://www.fostexinternational.com/d...pdf/FE83En.pdf
http://www.fostexinternational.com/d...df/FE103En.pdf
http://www.fostexinternational.com/d...df/FE126En.pdf
http://www.fostexinternational.com/d...df/FE166En.pdf
http://www.fostexinternational.com/d...df/FE206En.pdf
Old 4th August 2012, 07:20 PM   #2
Interested in the FE206en, do you have any enclosure to go with it? Prefer one the can produce good bass.
Sari
Old 5th August 2012, 02:28 AM   #3
Musik007's Avatar
Sari
Hi Sari,
The enclosures for FE206En are big, especially for the back loaded horn enclosure. The shipping cost of the big enclosure is very high. It will save a lot if you can make the cabinets in local. I can sell you the drivers.
Thanks,
Tony.
Old 5th August 2012, 03:10 AM   #4
frugal-phile(tm)
planet10's Avatar
The FE205 actually works better in the 208eSigma cabinet, Even better in a number of the 3rd party enclosures.
All are biggish. Best to get them locally built.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th August 2012, 01:10 PM   #5
Musik007's Avatar
Hi dave,
Thanks for your recommendation.
BR,
Tony.
dave
Full range Open Baffle with Current Drive knutn Full Range 37 15th February 2013 02:08 PM
Fostex full range Jamesuk1 Full Range 58 19th July 2008 04:46 PM
Fostex full range speaker help hifibuyguy Full Range 23 3rd December 2007 04:49 PM
4" full range for drive-in speaker... imix500 Full Range 14 13th July 2005 11:12 PM
NYC Fostex Full Range Bryan Full Range 0 12th March 2004 04:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
