Go Back   Home > Forums > > >
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 17th May 2011, 09:35 AM   #1
Musik007 is offline Musik007  Hong Kong
Musik007's Avatar
Birch Plywood Cabinets made by CNC machine
Default Birch Plywood Cabinets made by CNC machine
Hello,
I'm pleased to develop a new series cabinet made by CNC machine. High precision processing of CNC machine is able to cut any shapes on plywood. This is my first sample of a bookshelf cabinet for CHR-70. The material selected is Finland WISA birch plywood.
Old 17th May 2011, 11:01 AM   #2
_henry_ is offline _henry_  Australia
great news, im sure u will try some wild imagination soon
cheers
henry
Old 17th May 2011, 11:50 AM   #3
Charles Darwin is offline Charles Darwin  United Kingdom
With a CNC would it not be easy and better to NOT use right angles for the internal cavity so as to avoid parallel walls and the resulting standing waves?
Old 17th May 2011, 12:09 PM   #4
CopperTop is offline CopperTop  United Kingdom
I am liking that a lot! I've never made any speakers, but if and when I do, I will use that method.
The result of the unfinished or varnished ply will look very restrained and Scandinavian, or you can presumably veneer it. I'm almost tempted to start straight away...
Old 17th May 2011, 05:31 PM   #5
Musik007's Avatar
Hi henry,
I want to try something special.
Thanks,
Tony.
cheers
henry
Old 17th May 2011, 05:35 PM   #6
Musik007's Avatar
Hi Charles,
Thanks for your remind. I want to keep the internal volume unchanged as Till 70's. I will put damping material into the cabinet.
Tony.
Old 17th May 2011, 06:37 PM   #7
badman is offline badman  United States
badman's Avatar
Originally Posted by Musik007 View Post
Hi Charles,
Tony.
Asymmetrical "Wavy" walls would be the way to go... Just as easy but mobedda.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 17th May 2011, 07:04 PM   #8
CharlieLaub is offline CharlieLaub  United States
While you are considering changes... why not implement at least three holes in each piece in the same spot that could be used to align all of them. For instance, you could put a threaded rod through these holes to align the pieces and clamp them together while gluing the stack together...
Also, +1 on not using parallel, rectilinear inside walls.
-Charlie
Old 18th May 2011, 04:55 PM   #9
Musik007's Avatar
Hi Charlie,
Thanks for your recommendation. That is possible to do like this.
Thanks,
Tony.
-Charlie
Old 25th May 2011, 02:25 AM   #10
Musik007's Avatar
CNC programming and processing.
Birch Plywood Cabinets made by CNC machineHide this!Advertise here!
FS Morel drivers, custom CNC machined aluminum cabinets, Dayton cabinets Bronson_k Swap Meet 12 12th July 2015 08:39 PM
Cabinets made with Finland Birch Plywood Musik007 Twin Audio 161 28th February 2015 03:18 AM
Birch plywood finishing Vikash Multi-Way 102 23rd April 2010 10:50 PM
working with baltic birch plywood morbo Multi-Way 55 17th September 2005 05:09 PM
Where can I buy Baltic Birch Plywood? Richard Moon Multi-Way 3 4th December 2003 12:51 AM
