Go Back   Home > Forums > > >
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 7th March 2011, 05:22 AM   #21
EUVL is offline EUVL  Europe
Nothing to report.
But if you want to duplicate our BR box, please contact Mark L.
Patrick
Old 7th March 2011, 05:38 AM   #22
Musik007 is offline Musik007  Hong Kong
Musik007's Avatar
Cabinets made with Finland Birch Plywood
Patrick,
I like your BR box. I will contact Mark L.
Tony.
Originally Posted by EUVL View Post
Nothing to report.
Patrick
Old 7th March 2011, 06:12 AM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by _henry_ View Post
it seems the layers are very thick. 18mm with 3layers only?
how's the sound compared to good birch ply?
It is only 3 layers. The middle ply is bambbo blocks, the outer layers are strands of bamboo bonded together in a matrix. This makes it conceptually much like the aluminum skinned honeycomb used in airplanes and such.
It is stiffer, and sounds better than BB. It is also some 10x as expensive (ignoring that you have to pay for the veneer to cover the BB). To take max advantage it is more complex to cut and assemble. It is lovely with a clear coat.
Our earlier bamboo builds were with laminate outer plys (strips of bamcoo) and from early in its availability in north america (only 2 finishes), Even with lower stiffness ahead of BB.
As soon as we get the right drivers in them we will do a photoshop of the 3 sets we made with the stranded neopolitan,
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th March 2011, 06:17 AM   #24
frugal-phile(tm)
planet10's Avatar
Originally Posted by Musik007 View Post
dave,
At supermarket in China, I saw a kind of bamboo plate for cutting meats and vegetables using in kitchen. It is very solid and heavy with high density. I think this should be the one what you said the bamboo plywood.
Bamboo cutting boards. We can buy those too. they are a single layer side-by side laminate. Not as stiff or suitable as the plywood.
Materials lik this are the harbinger of building materials made of renewable grasses (notable bamboo & hemp)
dave
Old 7th March 2011, 06:49 AM   #25
Musik007's Avatar
Very nice cabinets, dave.
If I have the Chinese name of this bamboo plywood, I can find this material in China.
Thanks,
Tony.
Old 7th March 2011, 07:25 AM   #26
frugal-phile(tm)
planet10's Avatar
When i was googling bamboo ply i found at least 2 chinese websites. Emailed Mark at least one of them.
dave
Old 7th March 2011, 07:42 AM   #27
Musik007's Avatar
Yes, there are many bamboo plywood suppliers in China.
These bamboo plywood in 3 layers shown should be what you said, dave.
Thanks,
Tony.
dave
Old 7th March 2011, 09:06 AM   #28
Musik007's Avatar
dave,
Is it good to use thicker plywood 24mm at front panel for Pensil 10.2?
Thanks,
Tony.
Old 7th March 2011, 09:20 AM   #29
frugal-phile(tm)
planet10's Avatar
That is the strip outer layer. If you can find stranded it is quite a bit stiffer.
The stuff you pictured is still good, but the surface is softer than the stranded and easier to dent. The one plus is that it is quite a bit lighter.
dave
Old 7th March 2011, 09:22 AM   #30
frugal-phile(tm)
planet10's Avatar
dave,
Thanks,
Tony.
No. That will screw up the tuning. If you want to make the cabinets better than they already are put in some bracing. The brace that connects the back of the driver to the back of the box is particularily useful at improving the downward dynamic range, and the Alpairs are capable enuff to make good of it.
dave
Cabinets made with Finland Birch PlywoodHide this!Advertise here!
Birch plywood finishing Vikash Multi-Way 102 23rd April 2010 10:50 PM
Anyone trid to build cabinets using bamboo plywood? G Full Range 5 14th January 2008 06:27 PM
working with baltic birch plywood morbo Multi-Way 55 17th September 2005 05:09 PM
Baltic birch plywood users - impact strength? 454Casull Everything Else 16 5th April 2005 10:06 PM
Where can I buy Baltic Birch Plywood? Richard Moon Multi-Way 3 4th December 2003 12:51 AM
