Monoblock single ended KT88 - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 25th January 2013, 01:55 PM   #11
Musik007's Avatar
The double C-core output transformer was exclusively designed and produced for our Audiophile 300B SE mono block power amps.
Old 2nd February 2013, 06:04 PM   #12
Originally Posted by Musik007 View Post
Hello,
Thank you for your interest in our tube amps. I would recommend our 300B single end mono block power amps. All the transformers including high quality double C-core output transformers are hand made by the experienced transformer engineer, Kenneth in Hong Kong. The amplifiers are handcrafted in Hong Kong. We selected Jensen audiophiled capacitors, RMG, Kiwame and Dale audio graded resistors, Furutech IEC sockets, CMC tube sockets and binding posts... Every parts and components are used for high end sonic performance.
Tony.
do you have available or can make a stereo 300B amp? do you have other models available?
Old 3rd February 2013, 03:41 AM   #13
Musik007's Avatar
Hello Alejandro,
Yes, we also have 300B stereo block amp. See the pictures. Input and driver stages are 3x 6SN7, 2x 300B power tubes and 1x 5U4G/GZ34 rectifier.
300B amps are our main products. All the transformes and amps are handcrafted in Hong Kong.
The 300B stereo amp is by order.
Thanks,
Tony.
Another kt88 Monoblock Builders Thread foxfyre841 Tubes / Valves 3 25th November 2011 02:58 PM
Single ended amp, EL34, KT88 ideas?? bereanbill Tubes / Valves 15 16th May 2009 12:35 AM
Single ended KT88 question overdrajv Tubes / Valves 8 22nd December 2008 10:44 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Copyright 1999-2017 diyAudio
