Go Back   Home > Forums > > >
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 4th January 2011, 02:20 AM   #11
Musik007 is offline Musik007  Hong Kong
Musik007's Avatar
Custom-made Cabinet Order
More pictures about the clearance from the edge of the removable baffle for screwing the baffle. This is my Pensil 7 cabinet.
Old 4th January 2011, 02:31 AM   #12
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Hi Tony,
I just need a pair of those, so maybe I should give up now...
I think I need to reconsider about it, I am not so sure about having veneer as I think high gloss white will without doubt fit the decor of my home better.
Thanks,
Boris
Old 4th January 2011, 03:32 AM   #13
Musik007's Avatar
Boris,
You may contact other manufacturer to make high gloss white cabinet for you.
Thanks,
Tony.
Originally Posted by borispm View Post
Hi Tony,
Thanks,
Boris
Old 4th January 2011, 02:34 PM   #14
Musik007's Avatar
Boris,
Got the reply from the maker, they have 15mm thickness plywood. The price of the bookshelf cabinet with veneer is US$185/pair.
Thanks,
Tony.
Old 4th January 2011, 03:23 PM   #15
borispm's Avatar
Tony,
Thanks for your help. I will decide whether to get them or not later.
A million thanks,
Boris
Old 5th January 2011, 01:02 PM   #16
borispm's Avatar
Hi Tony,
Is the edge on the cabinet for mounting the baffle around 1" wide? I think I need to redesign my cabinet a bit if it is.
Thanks,
Boris
Old 6th January 2011, 01:53 AM   #17
Musik007's Avatar
Hi Boris,
The edge on the cabinet for mounting the baffle should be 15mm.
Tony.
Hi Tony,
Thanks,
Boris
Old 13th January 2011, 04:31 PM   #18
borispm's Avatar
Hi Tony,
Do you know any local carpenter who can help me with the cabinets? I think I need something more affordable as this is my first project and the drivers I've got are pretty economical and I don't want the cabinets to be more expensive than the drivers themselves. My budget is <HK$500 and I think I can do the final touch (vinyl, paint) myself.
I know this is sort of breaking the rule here and it may not be the right place to disclose the full details. I would appreciate if you can PM me or email me at borispmchan@hotmail.com
Thanks,
Boris
Old 13th January 2011, 05:20 PM   #19
Musik007's Avatar
Hi Boris,
I don't think the cost of cabinets made by local carpenter in Hong Kong will be less than HK$500. The material is not expensive, but the labour cost of carpenter is high, may be HK$800/day or more. The cheapest way is to buy material and try to make the cabinets by yourself. It may not need good quality as it is not a commercial item. There are a lot of plywood shops around us in H.K. Try to ask the shop to help you cut plywood into pieces you needed.
Thanks,
Tony.
Hi Tony,
Thanks,
Boris
Custom-made Cabinet OrderHide this!Advertise here!
where can I have a custom made heatsink? Stefanoo Solid State 47 26th January 2012 07:06 AM
Could I get custom drivers made by anyone? mondogenerator Multi-Way 14 24th October 2010 07:02 PM
Custom made passive x-overs RacerXtreme Multi-Way 4 21st December 2008 06:54 PM
Need a some custom aluminum enclosures made triden Everything Else 5 27th November 2007 02:29 PM
Made to order speaker cabinet supplier needed sharpi31 Multi-Way 1 26th July 2006 07:20 AM
Copyright ©1999-2017 diyAudio
