| Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers. |
#211 | |
Hello,
I also love the 6F3 amps for its smaller size, but the 6F3 amps are already discontinued and no any supply from the factory now and in the future. Sorry. Thanks, Tony. Quote:
#212 | |
Maybe you need to find another factory. |
#214 |
#217 |
If 6F3 amp is selling at $278 and on stock, why not buy PA0901A at $190? The performance of PA0901A is higher than 6F3 amp. There are more powerful and music details on PA0901A.
#218 |
Integrated Tube Amplifier – PA0901A
A minimalist integrated amplifier with one pair of RCA inputs and a passive volume control to attenuate the output of its enhanced classical tube circuit comprised of a 6N4 (12AX7 or ECC83) twin triode feeding a single 6P14 (EL84 or 6BQ5) per channel, and also with our advanced switching power supply to deliver a 3.5 watts output per channel Tubes • Driver - 6N4 (12AX7 or ECC83) • Power - 6P14 (EL84 or 6BQ5) Specifications • Power Output: 3.5W+3.5W @ 8 ohms • Frequency Response: 30-40Khz (+-1db) • Input Sensitivity: 500mV • Signal-to-Noise Ratio: -80dB / 3.5W • Residual Noise < 1mVac • Input AC Voltage: 100-250Vac • Power Consumption: 38W • Input Impedance: 50K ohms • Output Impedance: 4/6/8 ohms (Japanese Z11 steel core, EI48*24 Output Transformers) • Dimensions: 130mm (w) x 130mm (d) x 130mm (h) • Weight: 2.6kg • Input: RCA Jacks • Output: Banana Jacks • AC: Standard IEC Jack with Fuse protection (2A Fuse) Price: USD190 + shippig cost * Five colors are available now. |
#219 |
High quality PCB, parts and components of PA0901A:
#220 |
SPECIAL OFFER:
Hello, I'm glad to provide special offer on PA0901A in March. Brand new Mullard EL84 and Mullard 12AX7/ECC83 go with PA0901A amps instead of the standard Chinese tubes, but the price of PA0910A with the MULLARD tubes remains the same, USD190 + shipping cost. This special offer is exclusively provided by Twin Audio. Mullard EL84 are provided in matched pair. The special offer is valid until 30-March-2013. Brand New Re-issue MULLARD EL84 and 12AX7/ECC83 are from the New Sensor Corporation in New York. They feature warm, rich, thick tone, delivering all the sound you would expect from a tube with the Mullard name. Each tube comes in the original Mullard Retail Box. Thanks & Best Regards, Tony. Last edited by Musik007; 3rd March 2013 at 04:07 AM. |
| Sell beatiful small 6F3 small tube amp (used like new) | siliconray | Vendor's Bazaar | 0 | 1st March 2012 12:50 PM |
| Hifi 6N2+6P1 tube power amplifer $99 now!! | siliconray | Siliconray Online Electronics Store | 0 | 7th February 2012 07:18 AM |
| Beautiful super mini 6F3 2.5Wx2 tube amplifier - group buy | siliconray | Siliconray Online Electronics Store | 5 | 17th October 2011 02:55 PM |
| A few questions about transformer placement in an S5 K-12 tube amplifer | Maxwell Smart | Tubes / Valves | 10 | 9th August 2010 07:42 PM |
| Sales On Sound Vintage 40s Tube Amp Info | SOSamp | Tubes / Valves | 2 | 6th April 2010 04:38 AM |
