Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 13th August 2010, 04:28 PM   #31
Musik007's Avatar
Pureaudio 211 single end from China.
Old 13th August 2010, 04:33 PM   #32
Musik007's Avatar
Fostex 8" full range.
Old 15th August 2010, 02:28 PM   #33
Musik007's Avatar
Avantgarde Horn Speaker, Efficiency (1Watt/1m): 109 dB
Old 15th August 2010, 02:34 PM   #34
Musik007's Avatar
This is big Avantgarde Basshorn (subwoofer) with freqency range 18-350 Hz.
Old 15th August 2010, 02:41 PM   #35
Musik007's Avatar
The demostration room for Tannoy, Accuphase, Cabasse, Chario and Esoteric.
Old 16th August 2010, 03:45 PM   #36
Musik007's Avatar
Wavestream high powered V8 KT88 push pull in parallel mono block power amps. The style is so special.
Old 16th August 2010, 04:37 PM   #37
Musik007's Avatar
Audio Space tube amplifers.
Old 16th August 2010, 04:41 PM   #38
Musik007's Avatar
Vivid Audio G2 Guya speakers from South Africa.
Old 18th August 2010, 02:32 PM   #39
Musik007's Avatar
Naim audio system.
Old 18th August 2010, 02:35 PM   #40
Musik007's Avatar
Solution.
Help wanted from DIY audio forum guys from China , Hong Kong or Taiwan! gaborbela Solid State 11 5th October 2010 02:38 PM
High End/diy Audio Show? EDDIEMUNSTER Multi-Way 2 26th August 2006 10:47 PM
Frankfurt High-End Audio Show jcarr Everything Else 1 27th May 2003 05:31 PM
Copyright ©1999-2013 diyAudio
