| Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers. |
It is always very hot during July and August in Hong Kong. The outdoor temperature is over 34 degrees in day. People may not want to listen hot big tube amplifiers in hot summer. The small powered tube amplifiers are not so hot and more safe. So we continue to produce our desktop series. A new baby is coming...
#2 |
What is it?
It is a mini tube amplifier. In the beginning, we designed this 3-tubes amplifier without a tube rectifier. Less heat. Since we succeed to make ECC85-6L6 single end, read Mark's review, we believe ECC85 is able to match 6V6 as well. So we did it, the circuit is more simple, a single ECC85 pushes 6V6 in class A single end. 4.5W output power is achieved at tetrode connection. Thanks Thomas. He made a new nice amp. |
#3 |
Direct signal path (one input) is the best.
#4 |
#5 |
These are RCA smoked glass 6V6GT and Valvo ECC85 I keep. They are well matched and the overall sound of the amp is smooth, detailed and musical when pushing Mark Alpair 6 and CHR-70 bookshelf.
#6 |
The price of this desktop 6V6 SE is USD298 including Chinese 6N1(=ECC85) and 6P6P(=6V6GT). If replace Valvo ECC85 and RCA 6V6GT, just add USD52 with total USD350, you will have wonderful sound.
#7 |
The heavy duty 120W EI 86 power transformer is not hot even for long time use in summer. The choke is 10H/150mA for CLC filter.
#8 |
The output transformers used for this 6V6 single end is EI 57 x 30 mm with output 5W.
Primary impedance: 5K Secondary impedance: 0-4-8 ohms Primary current: 50mA Inductance: 26H Frequency range: 35Hz-20KHz Last edited by Musik007; 14th August 2010 at 03:29 PM. |
#9 |
AC input: 220V
#10 |
The speaker outputs can be easily selected 4 ohms and 8 ohms on a switch.
| 6550 SE class project (continued) | cadaverdog | Tubes / Valves | 9 | 12th May 2008 02:26 AM |
| Dipoles (continued)... | Nuuk | Multi-Way | 10 | 25th February 2006 07:52 PM |
| JP2.0 project continued | DIY_newbie | Multi-Way | 8 | 1st March 2005 08:56 PM |
| OTL, continued... | Joel | Tubes / Valves | 109 | 12th March 2004 05:20 PM |
| Slew Rate Limiting... continued. | Joel | Tubes / Valves | 31 | 4th February 2003 07:12 PM |
