Class T Amp For Twin Audio/ Markaudio? - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 24th June 2010, 09:19 AM   #1
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Wink Class T Amp For Twin Audio/ Markaudio?
I understand that Twin Audio is a specialist in tube amps, but tubes are inefficient, hot and not as durable as most solid state amps (need tube replacement from time to time), so I wonder if you guys can make solid states based on the very popular TA2024 chip? From your pictures, I believe you've got the top notch craftmanship (Tony, was that your partner who built those lovely amps? Please tell him they look terribly lovely!), and if you can make solid states in that style, I can assure you that they will be more popular than their counterparts!
I am looking forward to hearing your reply!
Best Regards,
Boris
P.S. Did Mark say anything about the sealed CHR 70? I hope he can give it a try!
Old 24th June 2010, 04:54 PM   #2
Musik007's Avatar
Hi Boris,
I have TA2024 amp and we made a TA2024 amp with preamp before, but I never experienced good sound TA2024 amps. There are a lot of class T amps based on TA2024, TA2020, etc in China. They are easy to build with suitable power supply. They are cheap. To build a good sound T amp is not easy. For tube amps, we can design and make circuits of tube amps, adjust working values and make use of different components to achieve different sounds and personnal tastes. We can make our own tube amps which would be different with others. We don't have idea about solid state amps. It is easy to buy existing TA2024 PCB from market, and there are many PCB and kits for this kind of T amp. We can build TA2024 amp with power transformer and put into chassis like diyers. However We like some different and creative stuffs. You can see our EF95-6V6, ECC85-6L6, EL84-EL84 PP..... All of those amps are special and with our own characteristics.
Mark would give comments about the sealed cabinet.
Thanks & regards,
Tony.
Old 24th June 2010, 05:03 PM   #3
Musik007's Avatar
This is the only one Class T amp we made. We added 5687 tube preamp to TA2024 power amp. Two power transformers were used, one is for tueb preamp and another is for TA2024.
Introduction to Twin Audio Musik007 Twin Audio 152 25th March 2015 01:36 PM
Twin Audio Interconnect Cable, Signalink Musik007 Twin Audio 8 14th September 2010 02:04 PM
FYI: Class D amp modules from Prism audio RaiTulo Class D 2 28th May 2009 04:30 PM
Class d audio power amp pr2don Class D 2 1st May 2006 05:08 AM
mmm.... zero-bias class B twin triode amp Circlotron Tubes / Valves 6 5th March 2003 12:49 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
