Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 22nd June 2010, 05:20 PM   #11
Musik007's Avatar
The power switch is on the right side of chassis.
Old 23rd June 2010, 03:54 AM   #12
Musik007's Avatar
Hi Mark,
A new desktop 6V6 push pull amplifier will be available in next month. The dimension is same as this 6L6 amp. It should better match with Alpair 10 and Alpair 12 as the output power is 12W.
Tony.
Old 24th June 2010, 08:46 AM   #13
Musik007's Avatar
One signal input keeps direct signal path.
There are 4 ohms and 8 ohms outputs for option.
Old 26th June 2010, 04:17 PM   #14
Musik007's Avatar
Specifications of transformers:
Power transformer:-
-AC input: 225V
-Size of steel core: 86x50mm
-Thickness of core: 0.5mm
-Output: 250V-0-250V/150mA, 6.3V/2.5A x2 & 5V/3A x1
Output transformers:-
Output power: 10W
Size of steel core: EI 76 x 40 mm
Primary impedance: 3.5K ohms
Secondary impedance: 0-4-8 ohms
Inductance: 25H
Primary current: 100 mA
Frequency Range: 30Hz-20KHz
The steel core is Japanese H10 in 0.35mm thickness.
Old 29th June 2010, 04:41 PM   #15
Musik007's Avatar
The size of this 6L6 amp is compact. We try to make this kind of single end tube amplifiers as small as possible. It can match style and sound with CHR-70, CHP-70, Alpair 6 nad Alpair 7.
Old 1st July 2010, 05:11 PM   #16
Musik007's Avatar
The circuit was designed and the amp was soldered by Thomas.
Old 4th July 2010, 04:05 PM   #17
Musik007's Avatar
The heart of the 6L6 amp.
Old 7th July 2010, 07:24 PM   #18
Musik007's Avatar
CDET 0.33uF/630VDC film capacitors are used between ECC85 and 6L6.
Old 10th July 2010, 05:40 PM   #19
Musik007's Avatar
The Japanese Matsushita 100uF/100V capacitors were used for the cathodes of ECC85 and 6L6.
Old 15th July 2010, 02:21 PM   #20
Musik007's Avatar
120W EI power transformer with AC input 230V.
100V EL34 Single End Class A amplifier Musik007 Twin Audio 18 26th April 2012 04:51 PM
6L6 class A single end amplifier Musik007 Twin Audio 33 28th April 2010 05:18 PM
Pure Class A Single End Amplifier Idea! Dxvideo Solid State 91 1st September 2008 10:54 AM
Single-end... which tube? Mr. Triatic Tubes / Valves 56 25th December 2004 09:08 AM
Copyright ©1999-2013 diyAudio
