diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Twin Audio (http://www.diyaudio.com/forums/twin-audio/)
-   -   Chokes for Tube Amplifers (http://www.diyaudio.com/forums/twin-audio/167135-chokes-tube-amplifers.html)
Musik007 19th May 2010 05:29 PM
1. 5H/120mA choke:
A small sized choke is suitable for small powered single end tube amps such as EL84, 6V6, 6L6, 6BM8, etc.
Specification:
Inductance: 5H
Current: 120 mA
Power: 12VA
DC resistance: 88 ohms
H14 steel core, core size: 48x20mm
Outer dimension: 70mmW(with feet), 50mmW(with cover), 45mmD and 43mmH
N.W.: 0.35 KG/pc
Length of wires: 25 cm
Made in Hong Kong.
Price: USD13/pc
Special Price: USD10/pc, valid until 30, June.
http://i30.photobucket.com/albums/c3...5H-120ma-3.jpg
http://i30.photobucket.com/albums/c3...5H-120ma-1.jpg
costis_n 21st May 2010 03:35 PM
Nice, now how about some of your nice output transformers?
Musik007 21st May 2010 04:41 PM
The 5K output transformers for EL84/6V6 single end are still available now. We can supply and custom make any other output transformers for single end and push pull tube amps. We will post other output transformers later.
Thanks.
Musik007 25th May 2010 02:33 PM
2 Attachment(s)
This compact sized choke can be used for internal and external applications.
Musik007 28th May 2010 04:48 PM
2 Attachment(s)
There are some 5H/120mA chokes on stock.
Musik007 2nd June 2010 04:19 PM
2 Attachment(s)
6 chokes were ready to be shipped to north Europe.
Musik007 5th June 2010 05:17 PM
2. 15H/120mA choke:
A small sized choke is suitable for small powered single end tube amps such as EL84, 6V6, 6L6, 6BM8 and preamp.
Specification:
Inductance: 15H
Current: 120 mA
Power: 20VA
H14 steel core, core size: 57x25mm
Outer dimension: 82.5mmW(with feet), 60mmW(with cover), 58.5mmD and 52mmH
N.W.: 0.70 KG/pc
Length of wires: 30 cm
Made in Hong Kong.
Price: USD20/pc
Special Price: USD15/pc, valid until 31, July.
http://i30.photobucket.com/albums/c3...5H-120ma-2.jpg
Musik007 11th June 2010 02:04 PM
2 Attachment(s)
15H/120mA choke.
EUVL 20th June 2010 05:54 AM
Tony,
I saw Poshan (Treasure Mountain) on the label.
They used to be at Tin Kwong Road, Tokwawan, right ?
Where are they now ? Can you give us a hint ?
Thx,
Patrick
Musik007 21st June 2010 03:02 PM
Hi Patrick,
Now Po shan is at 8D, Shun Wai Industrial Building, 15 Yuk Yat St., To Kwa Wan.
Thanks,
Tony.
Originally Posted by EUVL (Post 2221670)
Tony,
Thx,
Patrick
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
