Twin Audio Interconnect Cable, Signalink - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 18th May 2010, 05:52 PM   #1
Musik007's Avatar
Default Twin Audio Interconnect Cable, Signalink
We now have our own interconnect cable series, Signalink. The first interconnect cable is Signalink One. The source of the cable is a vintage Western Electric oil clothed copper wire which was selected and tested by Mr. Lu. He tested and audited a lot of Westeren Electric wires and found the performance of this oil clothed wire made him satisfied.
WBT 0840 silver solder was used onto the contacting points of Signalink One to enhance the sound performance. RCA plugs are Neutrik plugs which are widely used for audio in the world.
Price: USD65/pair for 1.5 meter.
Old 19th May 2010, 03:16 PM   #2
Musik007's Avatar
Hand-made interconnect cables for audio.
Old 20th May 2010, 05:18 AM   #3
Musik007's Avatar
The net weight of the cables with RCA plugs is 0.30 KG per pair.
Old 20th May 2010, 05:25 AM   #4
Musik007's Avatar
The outer diameter of the cable is 7.5 mm.
Old 22nd May 2010, 02:52 PM   #5
Musik007's Avatar
Fine quality Neutrik RCA plugs.
Old 26th May 2010, 03:37 PM   #6
Musik007's Avatar
Re
Old 27th May 2010, 03:39 PM   #7
Musik007's Avatar
Solder material is very important for the signal cables. We selected and used WBT 0840 silver solder which contents 4% silver. It can make the sound performance of the cable to be more refined and detailed.
Old 13th September 2010, 04:38 PM   #8
Is this IC specially designed for 300B SET amp?
Old 14th September 2010, 02:04 PM   #9
Musik007's Avatar
No.
If you were looking for the best interconnect cable ... lowtherdream Parts 3 13th August 2008 02:07 PM
Interconnect cable Midnite Mick Parts 3 3rd January 2007 06:47 PM
Bulk Interconnect Cable Bengali Parts 3 6th December 2006 07:32 AM
Interconnect, speaker cable break-in??? JojoD818 Chip Amps 6 29th December 2003 10:21 PM
UTP computer cable as audio interconnect supernet Everything Else 15 14th October 2002 03:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
