Solid Wood HiFi Stands - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 13th May 2010, 04:51 PM   #1
Musik007's Avatar
Default Solid Wood HiFi Stands
We are providing fine quality solid wood walnut stands for CD player, DAC, preamp, power amp and speakers. The density of the walnut wood is high and enough to support any hifi gears.
This is a standard sized walnut stand.
Dimension: 480W x 400D x 50H mm
Net Weight: 5.3 KG
Price: USD78/pc
Old 15th May 2010, 02:55 PM   #2
Musik007's Avatar
Can custom-make stands in different sizes.
Old 17th May 2010, 03:33 PM   #3
Musik007's Avatar
Bottom of stand.
Old 21st May 2010, 04:10 PM   #4
Musik007's Avatar
The thickness of the walnut stand is 50 mm.
Old 21st May 2010, 04:14 PM   #5
Musik007's Avatar
Walnut stands in size of 480W x 350D x 48H mm
Old 24th May 2010, 06:10 PM   #6
Musik007's Avatar
The solid wood stands have natural wood texture.
Old 26th May 2010, 04:31 PM   #7
Musik007's Avatar
Speaker also need good stands
Old 31st May 2010, 03:15 PM   #8
Musik007's Avatar
This walnut wood HiFi stand is one of our standard item.
Old 2nd July 2010, 04:26 PM   #9
Musik007's Avatar
The standard size of walnut HiFi stand:
Outer dimension: 480W X 360D X 115H mm
Inner dimension: 450W X 330D X 48H mm(size of plate)
Net Weight: approx, 5KG
Price: USD88 including 4 spikes.
Old 24th July 2010, 03:15 PM   #10
Musik007's Avatar
Mono block power amp could be put on this stand.
Solid Wood? Lewis Moon Multi-Way 15 29th September 2008 10:06 PM
Solid Wood Plinth jlsem Analogue Source 2 3rd August 2007 12:22 AM
MDF vs solid wood polvoson Multi-Way 28 8th June 2006 05:40 PM
using one piece of solid wood for an enclosure Jared Multi-Way 13 8th May 2003 12:45 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
