Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 9th June 2010, 04:55 PM   #11
Musik007's Avatar
Some vintage capacitors were used into this amplifier.
Old 3rd July 2010, 06:51 AM   #12
soshs is offline soshs  China
Integrated amp? Does it contain a pre-amp?
Old 3rd July 2010, 05:50 PM   #13
Musik007's Avatar
This is a integrated amp and contains input stage and phase inversion stage which function like preamp.
Thanks.
Old 24th July 2010, 02:25 PM   #14
Musik007's Avatar
These vintage Sprague ATOM paper caps are very rare now.
Old 13th September 2010, 04:32 AM   #15
JoMoCo is offline JoMoCo  United States
Default North American Voltages / Hz
Can this amp be wired for 120VAC or 240VAC 60Hz?
Old 13th September 2010, 08:00 AM   #16
Musik007's Avatar
Hello,
No. This amp is 220VAC. If you need 120VAC or 240VAC 60Hz, we can change the power transformer and the price remains the same.
Thanks,
Tony.
Bell 2420 tube amplifier. Bias question. 6v6 push pull The Donk! Tubes / Valves 5 30th May 2013 09:40 AM
EL84 Push Pull Integrated Amplifier Musik007 Twin Audio 17 12th September 2010 05:05 PM
MA 6P1 6AQ5 Push-Pull Valve Tube Integrated Amplifier bitemeboat Tubes / Valves 6 4th May 2010 02:03 AM
Simple 6V6 Push Pull Schematic dsndblm Tubes / Valves 13 26th September 2009 02:52 AM
6V6 Push Pull J_Hart_14 Tubes / Valves 16 4th December 2008 08:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
