71A Direct Heat Triode Single End Class A Amplifier - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 3rd May 2010, 04:36 PM   #11
Musik007's Avatar
115VA power transformer in EI 76x50 was used on this 71A SE. The power transformer was made in Poshan, Hong Kong.
Old 6th May 2010, 02:38 PM   #12
Musik007's Avatar
This maple wood frame is hand-made. It is natural color of the wood.
Old 6th May 2010, 02:45 PM   #13
Musik007's Avatar
The 71A SE is our unique design and was made and soldered by Thomas.
Old 6th May 2010, 02:54 PM   #14
Musik007's Avatar
We selected German ROE 100uF/100VDC golden capacitors as the cathode caps for 71A and 6SL7.
Old 6th May 2010, 03:01 PM   #15
Musik007's Avatar
The capacitors using at the coupling stage between 6SL7 and 71A is CDET 0.33uF/630VDC film caps from USA. The quality of CDET caps is very good. We're using them in some of our tube amps.
Old 6th May 2010, 03:19 PM   #16
Decker is offline Decker  United States
Beautiful! You are giving me GAS!
Old 6th May 2010, 03:44 PM   #17
Musik007's Avatar
Thank you.
Old 6th May 2010, 03:58 PM   #18
kevinkr's Avatar
Tony, Thomas, very nice work.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 6th May 2010, 04:02 PM   #19
Musik007's Avatar
Kevin,
Thank you so much.
Tony.
Old 7th May 2010, 07:33 AM   #20
Originally Posted by Musik007 View Post
This is the output transformers for 71A single end. The primary impedance is 5K and secondary impedance is 8 ohms and 16 ohms. The output power is 7W.
I think you mean the output power is ~ 0.7W
I am looking forward to using some of these in an amp project - supposedly, they present music with a nice sense of delicacy and nuance, though can sound (visually) flat at times... We will see.
“We must have concepts in order to function; they are not the problem. The problem is created when we believe they are the truth.” Charlotte Joko Beck
6L6 class A single end amplifier Musik007 Twin Audio 33 28th April 2010 05:18 PM
Discrete Single End TRUE Class A HeadPhone Amplifier lineup Headphone Systems 30 29th May 2009 09:44 PM
Pure Class A Single End Amplifier Idea! Dxvideo Solid State 91 1st September 2008 10:54 AM
Copyright ©1999-2017 diyAudio
