Go Back   Home > Forums > > >
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 7th May 2010, 01:29 PM   #21
Musik007 is offline Musik007  Hong Kong
Musik007's Avatar
71A Direct Heat Triode Single End Class A Amplifier
Hello,
The 7W is the output power of the outpout transformer of 71A SE. The output power of 71A single end class A is 0.8W.
I feel the sound of this low powered directly heated triode, 71A is so musical, smooth and a bit slow like listening to LP. This should be a kind of vintage sound of tube amplifier.
Thanks.
Old 12th May 2010, 03:11 PM   #22
Musik007's Avatar
The vintage Cornell Dubilier Flat Pack 270MFD /420VDC capacitor was used on power filter.
Old 28th May 2010, 03:33 PM   #23
Musik007's Avatar
The input selector is from Noble, Japan.
Old 21st July 2010, 02:20 PM   #24
Musik007's Avatar
A new 71A amplifier is being made for a local customer. The circuit is same as the first one, 6SL7-71A class A single end with 5Y3 rectifier.
Old 21st July 2010, 03:08 PM   #25
Musik007's Avatar
The power transformer, output transformers and choke are made in Hong Kong.
Old 21st July 2010, 04:12 PM   #26
Musik007's Avatar
The 120VA power transformer was particularly produced for the 71ASE. The core is H14 EI96x32.
Old 21st July 2010, 04:17 PM   #27
Musik007's Avatar
The craftsmanship of the power transformer from Po Shan is good.
Old 21st July 2010, 05:07 PM   #28
Musik007's Avatar
These are 15W output transformers made for 71A single end. Primary impedance is 4.8K ohms and secondary is 4 ohms and 8 ohms. The EI core is Z11 0.35 mm in size 76x26mm.
Old 23rd July 2010, 02:38 PM   #29
Musik007's Avatar
Install the output transformers onto the 71A amp.
Old 23rd July 2010, 03:21 PM   #30
Musik007's Avatar
The power transformer fits the 71A amp.
71A Direct Heat Triode Single End Class A AmplifierHide this!Advertise here!
6L6 class A single end amplifier Musik007 Twin Audio 33 28th April 2010 05:18 PM
Discrete Single End TRUE Class A HeadPhone Amplifier lineup Headphone Systems 30 29th May 2009 09:44 PM
Pure Class A Single End Amplifier Idea! Dxvideo Solid State 91 1st September 2008 10:54 AM
