| Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers. |
For these hand made output transformers for EL84/6BQ5 and 6V6 single end amplifiers, We used them in our EF95-EL84 single end and EF95-6V6 single end amplifiers. We think that they performed very well and the price is affordable.
Power: 6W Size of steel core: EI 66 x 33 mm Primary impedance: 5K ohms Secondary impedance: 0-4-8 ohms Primary inductance: 11H Primary current: 60 mA Frequency Range: 30Hz-20KHz N.W.: approx. 940 gm per piece, 1.88 kg per pair Price: US$45/pair ![]() ![]() ![]() Can buy optional steel covers for the transformers. The size of cover is 80W x 90D x 80H mm and sell at US$5/pc.
#2 |
#3 |
#4 |
Hmm, these transformers look very tempting for a small 6BQ5 SE amp I want to do sometime later this year. Any idea what shipping costs to MA, USA might cost? Pair with covers.
Can you tell us a little more about the construction techniques used - they do look nice and appear to be interleaved?
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#5 | |
I don't have the details about the construction techniques of the output transformers as they may be secret, but according to the maker, the output transformers are winded by old techniques and paper shielding is used on each layer. The insulation material is yellow varnished silk tape.
Can you let me know the full name of MA? Thanks. Tony. Quote:
#6 |
MA is the standard two letter abbreviation the USPS uses for Massachusetts. (Noted in the location information in my moniker.)
Also what is the dc current rating of the primary? (Or what current do you run them at?) I'm definitely interested, depends a lot though on shipping costs.
"Extraordinary claims require extraordinary evidence." - Carl Sagan Last edited by kevinkr; 9th April 2010 at 04:52 PM. |
#7 |
OK, will ask the shipping cost tomorrow.
The DC current rating of the primary is 70mA. Thanks. |
#8 |
Hi Thomas,
Please also send me a PM through diyaudio with the information - that way I will be sure to see it. Thanks, Kevin
#9 |
#10 |
We are able to custom-make and sell EI transformers including power transformer, input/output transformers and chokes for tube amplifiers.
| My first amp project, 6BQ5 (EL84) Single-End | Cifrocco | Tubes / Valves | 11 | 21st May 2012 01:43 AM |
| EF95-EL84 single end integrated amplifier | Musik007 | Twin Audio | 40 | 23rd October 2010 03:26 AM |
| Output Transformers for an EL84 Push-Pull Amp | boneshaker | Tubes / Valves | 2 | 3rd August 2006 07:52 PM |
| Dynaco Z-565 Output Transformers (PP EL-84/6V6) | Flodstroem | Swap Meet | 3 | 4th April 2006 07:22 PM |
