| Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers. |
#21 | |
Thanks, Kevin. The performance of this low-priced output transformer is quite good. Mark loves the sound of 6V6 on these output transformers.
The power output of vintage 45 power triode is approx. 2W at load resistance 4600 Ω. This 5K transformer can be used on 45. Have fun on diy tube amplifiers! Tony. Quote:
#22 |
#23 |
The steel covers for these output transformers just arrived. The dimension of the cover is 80x90x80H mm.
#24 |
The steel covers and the output transformers.
#25 |
Cool, can't wait to get my hands on them..
These are most probably destined for a small 45 based amplifier, although I might conceivably do something with a pair of Tele 6BQ5 I have knocking around the place.
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#26 |
Hi Kevin,
The above pair transformers and covers are for you. I already packed and will send to you today. Thanks. Tony. |
#27 |
Hi Kevin,
Your output transformers were sent via air parcel service by HK post office. This is the packing. The fine carton box is originally for Alpair 7 drivers. |
#28 |
Hi Tony,
I had a mod remove the pictures because included in one of those was my home address which I never want published on the web. No harm done. Everything looked well packed.. You can send documentation to my email address in the future - it's a lot safer.. Thanks, Kevin
#29 | |
Hi Kevin,
That's OK. No worry, you can also ask me to modify the photos, I can do that. Thanks. Tony. Quote:
#30 |
The 5K single end output transformers are available now.
| My first amp project, 6BQ5 (EL84) Single-End | Cifrocco | Tubes / Valves | 11 | 21st May 2012 01:43 AM |
| EF95-EL84 single end integrated amplifier | Musik007 | Twin Audio | 40 | 23rd October 2010 03:26 AM |
| Output Transformers for an EL84 Push-Pull Amp | boneshaker | Tubes / Valves | 2 | 3rd August 2006 07:52 PM |
| Dynaco Z-565 Output Transformers (PP EL-84/6V6) | Flodstroem | Swap Meet | 3 | 4th April 2006 07:22 PM |
