EL84 Push Pull Integrated Amplifier - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 6th May 2010, 04:32 PM   #11
Musik007's Avatar
Originally Posted by stalker View Post
Musik007, you build beautiful amps.
Hi stalker,
Thank you.
Tony.
Old 2nd June 2010, 02:34 PM   #12
Musik007's Avatar
Re
Old 24th July 2010, 02:48 PM   #13
Musik007's Avatar
Can also apply 12AT7/ECC81/6201/6060 in the input stage of this amp. The sound of mid-mu triode 12AT7 is smoother than hi-mu triode 12AX7.
Old 24th July 2010, 08:02 PM   #14
tinkerbelt's Avatar
What are the inputs? Is there a phono input?
Old 25th July 2010, 05:04 PM   #15
Musik007's Avatar
There are two signal inputs. No phono input.
Thanks.
Old 30th August 2010, 05:58 PM   #16
JoMoCo is offline JoMoCo  United States
Default El84 6BQ5 Monoblocks?
Any plans to build mono blocks like the Eico HF12 or better and simplier the HF14 amps only in the future or maybe custom?
Best Regards,
Jon
Old 31st August 2010, 02:19 AM   #17
Musik007's Avatar
Hi Jon,
Eico HF12 and HF14 are class vintage mono blocks with very high performance. We don't have plans to build EL84 mono blocks due to high budget and demand of market, but we accept custom make. What we are interested now is to build small EL84 single end and small EL84 push pull for desktop with PC or small audio system at home.
Thanks,
Tony.
Best Regards,
Jon
Old 12th September 2010, 05:05 PM   #18
Musik007's Avatar
This amplifier is sold.
Hum with EL84 Push-Pull Kashmire Tubes / Valves 10 30th December 2009 12:15 AM
EL84 push pull slideman82 Tubes / Valves 4 19th June 2009 03:40 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
EL84 push pull idea mark_titano Tubes / Valves 20 13th June 2005 02:51 PM
EL84 Push Pull amp. hacknet Tubes / Valves 8 23rd September 2004 05:53 AM
Copyright 1999-2017 diyAudio
