Go Back   Home > Forums > > >
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 13th March 2011, 03:47 AM   #61
anystereo is offline anystereo  United States
Tony ,
I have a pair of WE300B in my bottlehead parafeed amps and like to roll a few other types, can you confirm the electrical characteristics are the same as the Western electric's?
David
Old 13th March 2011, 04:50 PM   #62
Musik007 is offline Musik007  Hong Kong
Musik007's Avatar
New 300B single end
Hi David,
Full Music 300B can directly replace WE300B on 300B tube amp, but the electrical characteristics between the two are not same.
Thanks,
Tony.
Originally Posted by anystereo View Post
Tony ,
David
Old 10th February 2013, 04:24 PM   #63
Musik007's Avatar
New 300B single end
New 300B single end with separated power supply were built. 6SN7-300B with double C-core output transformers and the power supply was separated from 6SN7, 300B tubes and output section. The tube rectification is 2x5U4G. The sound is silky and detailed.
Old 10th March 2013, 10:04 AM   #64
Sariputa is offline Sariputa
Hi! Tony are you selling this?
Old 10th March 2013, 01:36 PM   #65
Musik007's Avatar
New 300B single end
Hello,
Yes, we sell.
Tony.
Old 7th April 2013, 05:12 PM   #66
davynkh is offline davynkh
Hi Tony
Do you make 300B parallel mono block?
Old 8th April 2013, 12:23 PM   #67
Musik007's Avatar
New 300B single end
Hello,
We don't make 300B parallel mono block amps at the moment.
Thanks,
Tony
Originally Posted by davynkh View Post
Hi Tony
Old 4th May 2013, 05:03 PM   #68
zman01 is offline zman01  Bangladesh
New 300B single end
Beautiful amp Tony.
Old 4th May 2013, 05:14 PM   #69
Egindin is offline Egindin  United States
Indeed, a beautiful amplifier. Who made the output transformers and where can one get those pretty transformer casings?
Old 4th May 2013, 07:14 PM   #70
jakubg is offline jakubg  Slovakia
It look even better on the inside. Beautiful clean work.
New 300B single endHide this!Advertise here!
WTB single used 300B for tests guglielmope Swap Meet 1 16th September 2008 06:26 PM
The end of the 300b Dream? duderduderini Tubes / Valves 15 27th February 2008 05:58 AM
Mission 300b parallel single ended duderduderini Tubes / Valves 1 17th October 2007 09:21 AM
Single-end... which tube? Mr. Triatic Tubes / Valves 56 25th December 2004 09:08 AM
Copyright ©1999-2017 diyAudio
