Go Back   Home > Forums > Commercial Sector > Manufacturers > Twin Audio
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Old 10th March 2010, 03:37 PM   #1
Musik007's Avatar
Default 12AX7-6SN7 Preamplifier
Twin Audio 12AX7-6SN7 preamplifier
This is our own preamp circuit which designs to combine 12AX7 and 6SN7 in one preamp and with 6X5 rectifier and 6SN7 regulation.
Old 11th March 2010, 02:11 AM   #2
Musik007's Avatar
12AX7 twin triode SRPP circuit.
Old 11th March 2010, 04:04 PM   #3
Musik007's Avatar
Power section of the preamp.
Old 11th March 2010, 04:09 PM   #4
Musik007's Avatar
Two inputs and one output.
Old 11th March 2010, 04:16 PM   #5
Musik007's Avatar
Obony chassis, nice wood texture.
Old 11th March 2010, 04:17 PM   #6
Musik007's Avatar
GE 6X5 rectifier.
Old 11th March 2010, 04:19 PM   #7
Musik007's Avatar
High quality CMC bakelite tube sockets.
Old 11th March 2010, 04:20 PM   #8
Musik007's Avatar
Inside view:
Old 11th March 2010, 04:24 PM   #9
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
great looking ;
but - why - on earth - you are using ECC83 in line stage ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 11th March 2010, 04:42 PM   #10
kevinkr's Avatar
Hint: Try 6SN7 in SRPP for line stage... I found it to be quite nice despite the mis-application. (Have built several as long as 10yrs ago, have one now for back up to my 26DHT PTLT)
I went through a dubious phase of using SRPP with 12AX7, whilst it sounds ok, the actual output impedance of this combination is >10K, not great for driving anything but a CF IMHO..
A gain of 20dB or less is generally more than adequate for a line stage, and an SRPP connected 6SN7 will give you that with an output impedance of around 1K.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
6SN7/6SN7 Aikido + CS4398 DAC = HEAVEN john65b Tubes / Valves 19 10th January 2010 03:13 PM
12ax7 nigelwright7557 Tubes / Valves 6 1st June 2008 02:54 PM
12AX7 how many is enough? Sambeaux Tubes / Valves 19 23rd March 2007 07:31 PM
12ax7 Matthewong Tubes / Valves 0 12th June 2005 04:54 PM
12ax7 > 6sn7 > 300b TunaFish Tubes / Valves 4 21st June 2004 05:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
