| diyAudio Sponsor | ||
I found the 6JC6 tube mentioned in Peter Millett's page. This is a frame grid pentode for IF amplification. When triode strapped, it has good gain. The 3 V version 3JC6 was sold at AES at only 0.50 per unit. However, I could not find any one discussed about this tube for audio use. Can this tube be used to drive a 2A3 SET? What would be the down side? BY
Bing Yang |
#2 | |
So far as using it to drive a 2A3, your best bet for that would be to use it as the CF in a Kimmel Mu Stage. Given the high Vhk rating (200V) the high g(m) (15mA/V) it would work just fine for that. Unless you're contemplating driving the 2A3 into Class AB2. For that, you'd be better off going with a MOSFET driver. |
#3 |
Thanks for the reply. I actually think about using it as the driver tube together with a MOSFET CCS at anode. Will it sound good?
Bing Yang |
#4 | |
#5 |
I bought some 3JC6A from Antique Audio Supply during sale last year. I finally got around to put it together as the driver for my 2A3 SET. I connected the heater in series so that I can use the existing 6 volt filament supply. The tube is triode strapped. As I don't know the correct way to triode strap this tube, I simply copied how Marantz 5 did. I connected plate, screen, and suppressor altogether. The supply voltage is 281V. The load resistor is 20K Ohm. The cathode resistor is 100 Ohm. I tried four tubes from ECG and Zenith. They all have plate voltage from 97 - 120 V and cathode voltage from 0.8 - 0.9 V. The tube should be pretty linear at this bias point.
Compared with my previous driver, EH 6C45pi, the gain is about the same. The sound of the amp is good. I think 3JC6A actually has more ambient details. However, I cannot tell the differences without side to side comparison. I am very happy considering that this tube was on sale at 50 cents each. I also bought Sylvania brand. I have to check and see whether there is any sound difference among different brands.
Bing Yang |
| triode strapped tetrode | nhuwar | Tubes / Valves | 2 | 2nd February 2008 10:14 PM |
| Triode strapped tetrode | nhuwar | Tubes / Valves | 5 | 7th May 2007 02:08 PM |
| PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode | percy | Tubes / Valves | 23 | 22nd January 2007 01:36 AM |
| 5763 Triode Strapped | wrenchone | Tubes / Valves | 3 | 5th August 2006 07:59 PM |
| 6L6 Triode strapped amp suggestions | bobhayes | Tubes / Valves | 8 | 28th September 2005 07:37 AM |
| Page generated in 0.09348 seconds (75.48% PHP - 24.52% MySQL) with 10 queries |
