DHT Triode Amp Project
Old 17th January 2003, 11:34 AM   #11
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
SV572-30 driving 2A3 SE works well.
He he
And I thought I was going into overkill on the driver.
Almarcy
How's the hum?
What's the ratio of the IS transformer?
Old 17th January 2003, 05:51 PM   #12
Bas Horneman is offline Bas Horneman  Netherlands
Bas Horneman's Avatar
John,
Just checked out your website! Well done! Makes for good reading!
Will link to it soon!
Have a good weekend.
Bas
Old 17th January 2003, 06:49 PM   #13
dhaen's Avatar
Thanx Bas,
It's still rather "unrefined". I'll add and refine in time, and hopefully it'll mature.
Have a good weekend too; I'm working.
Old 17th January 2003, 09:04 PM   #14
almarcy is offline almarcy  United States
Wink hum
I got no stinking hum.
IT is 1:1
Happy Ears!
Al
Old 17th January 2003, 10:17 PM   #15
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default NO HUM.
Al,
Do you care to clarify on how you heat the room?
Frank
Old 18th January 2003, 12:27 AM   #16
Cool heat
I live in Phoenix, Arizona. The few kilowatts from the stereo are masked by the megawatts from the Sun
Driving PDQ1500, pair of 80 Hz ehorns with Lambda TD15 and Mission M72.
Nice tunes
Happy Ears!
Al
Old 18th January 2003, 12:35 AM   #17
fdegrove's Avatar
Default CACTUS?
That explains it.
Frank
Old 3rd February 2003, 11:26 PM   #18
gilid is offline gilid
Default Evolution of the Power Supply
First, I would like to thank all those who posted to this thread.
My thoughts are now turning to the power supply. I am considering using two seperate power supplies: one for the 2A3 and its driver tube, and a separate power supply for the 572-3. The intent is to minimize ps-sourced distortion, and maximize weight
Rectification will be tube based.
So far, I have not been able to source a suitable transformer for the 2A3. The only one with 2.5 v secondaries is the Hammond,which is not available with 220V primaries. Ideally, the amp will have dual primaries, allowing world wide operation.
Smoothing will be with pi filters, c-l-c, perhaps dual pi. I am thinking of completely eliminating electrolytic capacitors, and using several(relatively) ac motor start polypropelyne caps. I have a small box of 50 uf 250V caps, which look like they might work.
As soon as I put together a schematic, I will post it, but as always, comments are appreciated.
Gilid
DHT Triode Amp ProjectHide this!Advertise here!
DIY triode DSP_Geek Tubes / Valves 2 10th September 2008 05:03 AM
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 12:36 AM
ts9 pt9 triode desperateaudio Tubes / Valves 0 8th February 2006 06:58 AM
UL to triode kathodyne Tubes / Valves 55 21st August 2005 09:05 PM
