| diyAudio Sponsor | ||
Hi!
I've been thinking about doing a linestage and would like to do it around the power supply section should be flexible to do the 12au7 grounded grid, foreplay and the 5687 in diyparadise. Can you guys help me with some power supply diagrams using the 6CA4/EZ81 rectifier? Transformer choices are open, will just have it made after the final diagram is settled. Also have a 20/20/20 uF 450v can cap (if it can be considered), not considering putting a choke. Thank you guys in advance. dudong |
#2 |
Download PSU Designer: http://www.duncanamps.com/psud2/index.html
And you should definitely use more than 60uF for a line stage, and chokes are recommended unless you go with a regulated PSU. |
#3 | |
The smallish first cap more or less sets the desired output voltage. It was designed using only PSUD2, results were within 2 percent or so of the simulation, and including the voltage divider to elevate the heaters (mandatory in the Morgan-Jones amp) is very quiet. You can also easily add one more RC stage to give more ripple suppression... As phn noted 60uF will probably be not enough for a linestage... Oliver |
| circuit diagram for LMI-32216A RCA ORTHOPHONIC POWER AMPLIFIER | renjiish | Tubes / Valves | 4 | 12th March 2011 09:18 AM |
| Changing from 6X4 to EZ81 | Mrpong | Tubes / Valves | 3 | 30th June 2006 11:34 AM |
| looking for power supply diagram SE 813 45 Watt | flyingman | Tubes / Valves | 1 | 16th February 2005 04:30 AM |
| Philco power tranny diagram/5u4 supply | Dr.Frankenstein | Tubes / Valves | 0 | 7th September 2004 11:08 PM |
| szekeres head amp supply diagram needed | newbie04 | Solid State | 2 | 25th November 2002 03:33 PM |
| Page generated in 0.08229 seconds (71.18% PHP - 28.82% MySQL) with 11 queries |
